It is currently Fri Oct 09, 2026 5:03 pm
Vehicle: suzuki sj70 1994
Post Posted: Thu Feb 14, 2013 3:02 pm
I have a 94 wide track just want to know if the rear diff is the same ratio as the front ? thank you zookers
Post Posted: Thu Feb 14, 2013 3:18 pm
Yes, other wise you'd get transmission wind up & stuff would break.
Post Posted: Thu Feb 14, 2013 3:27 pm
thank you for that, you don't need a tractor to pull a hoe
Post Posted: Thu Feb 14, 2013 4:08 pm
WT front diff is only 2 pinions and 22 spline.
Yes ratio is same as rear, and will bolt in, but axles wont, fit without side gear change,
and 2 pinions are not really strong enough for the rear.
So depends what you trying to do.
Users browsing this forum: No registered users and 154 guests
