Joined: Fri Sep 17, 2010 8:42 am Posts: 262 Location: Beeliar WA
Vehicle: 2004 Jimny 1.6
Posted: Mon Feb 18, 2013 12:14 pm
Hey guys, This is a post I made from another topic I'm looking for some more answers I have a 2inch efs lift and 235/75r15 Had the crazy death wobble, replaced left front wheel bearing ( broken) and king pin bearings wheel balance and alignment
Got heaps better. Still shimmying around and hard to drive on the highway.
Fitted a RTC and it's a little better.
When I had the alignment done it was noted that it had neg castor angle.
My question is this, Positive castor is better yes? Do I need to change the rear bushes as well as the front?
What brand does everyone recommend and where can I get them? How much degree should I be looking at? thanks guys. Sorry for the repost,
Vehicle: suzuki jimny 2002
Posted: Mon Feb 18, 2013 4:26 pm
Yes you want positive castor. The Jimny Standard could nilly use the castor correction as from the factory it wasnt great. And Bushes that correct the caster are fine. i used poly bushes and like them and they wear well/strong. They are all set up to pretty much adjust it the same amount. Rear bushed to not need to be changed as the wheels do not turn
Posted: Wed Feb 20, 2013 6:09 pm
I never actually measured. but they would estimate to be about double what the offset bushs give you. But the big plus was they pushed the diff forward a little more than a 1" i have 3inch lift.
Users browsing this forum: Google [Bot] and 192 guests
