It is currently Thu Oct 15, 2026 11:38 pm
Vehicle: 91 sierra, g16b,lift,30's
Post Posted: Mon Feb 18, 2013 6:23 pm
So I've got a Suzuki sierra 91 hardtop with a g16b in it. Ever since the conversion I've lost my windscreen wipers. Currently I've pulled out washer bottle and disconnected the wires as I've got my intake box in that position. Are any of those wires some way related to having the washer bottle hooked up. I've replaced the fuse. I've been told its a dash out job to replace the motor, I won't be doing that no way! However I will be getting the sabre saw out and cutting out a section of dash above the motor. Now before I go doing this will I be able to pull it out successfully if I cut a hole in that area? There's no hard to reach bolts???
This zook will soon be a bush/weekend hack so I really don't care on the hole lol!
Vehicle: 91 WT 1.6EFI
Post Posted: Mon Feb 18, 2013 8:07 pm
Ive got my bottle out for the same reason and my wipers still work.
Post Posted: Mon Feb 18, 2013 8:21 pm
Pulling the dash on a sierra isn't a hard job.
Post Posted: Mon Feb 18, 2013 8:51 pm
X2....
Softtop it's piece of cake, just fold the screen down.
Tintop is a bit more involved but certainly doable in a few hours.
Before you get carried away though, have you checked the wiper motor has power at the plug and the earth cable is intact?
Post Posted: Tue Feb 19, 2013 5:05 am
Ill be checking that this morning before I cut my hole
Post Posted: Tue Feb 19, 2013 7:46 am
Do hard tops have the little access panel that you can pop off to get to the wiper motor? Even if you just removed the glove box you might get pretty close to it. Just throwing out some ideas before you start chopping.
Post Posted: Tue Feb 19, 2013 10:14 am
Yeah it's got the access panel. Ill have to have a look at the glovebox trick
Users browsing this forum: Bing [Bot] and 314 guests
