It is currently Sat Oct 17, 2026 11:59 am
Vehicle: 1985 Suzuki Sierra
Post Posted: Wed Feb 20, 2013 5:09 pm
Hey probably be covered a million times but can someone tell me what the NT diff ratios are compared to the WT. Also what the 1L transfer case ratio to the 1.3L.
Post Posted: Wed Feb 20, 2013 5:33 pm
1.3: high 1.409, low 2.21, diff 3.9 (nt) 3.7 (wt)
1.0: high 1.59, low 2.55, diff 4.1
Also consider first gear for a 1.0 is about 3:1, for a 1.3 it's 3.65:1
Some of these numbers might be a bit loose, they're from memory.
Post Posted: Wed Feb 20, 2013 6:54 pm
Thanks. Also The wt and nt axle splines are they the same? So I can use a nt diff center in a wt diff housing with the wt axles?
Post Posted: Wed Feb 20, 2013 7:07 pm
Yes..
Post Posted: Wed Feb 20, 2013 7:11 pm
okay awesome!
Vehicle: 03 Jimny
Post Posted: Wed Feb 20, 2013 7:29 pm
Only a nt 1.3 center you can. 1l nt center will not fit.
Users browsing this forum: No registered users and 167 guests
