http://auszookers.com/forum/
Simple wiring question
http://auszookers.com/forum/viewtopic.php?f=5&t=39125
Author:  shark [ Wed Feb 20, 2013 7:28 pm ]
Post subject:  Simple wiring question
Can you solder wires that are used in a wiring loom such as the Baleno where a computer is used.
Author:  royce [ Wed Feb 20, 2013 7:56 pm ]
Post subject:  Re: Simple wiring question
power and earth wires yeah
injector and sensor wires mostly
the 02 sensor is likely a shielded wire, its best not to muck with this one as cutting the shielding away to join it might cause problems
Author:  shark [ Wed Feb 20, 2013 7:58 pm ]
I had to cut the one that goes in the exhaust as it didn't reach.
Bugger
Author:  atari4x4 [ Wed Feb 20, 2013 8:00 pm ]
loom side of the o2 sensor plug should be alright?
it's just normal wire... the actual o2 sensor wires are shielded. :?
Author:  grototech [ Wed Feb 20, 2013 8:05 pm ]
cutting and soldering them is fine..... No problem what so ever
Author:  royce [ Thu Feb 21, 2013 6:22 am ]
Some Vit ones are shielded all the way in, Sure the G13bb in the LJ is too
Author:  droverdave [ Thu Feb 21, 2013 8:15 am ]
I have successfully joined TV arial wire, which is double shielded stuff with weird plastic coating in there as well.
Just do your best too keep the sheilding stuff in tact, it doesnt have to be perfect, it just has to be there.
