It is currently Sun Sep 27, 2026 5:27 pm
Vehicle: 91 WT 1.6EFI
Post Posted: Fri Feb 22, 2013 2:38 pm
so I bought this Maruti front section a week ago and took it to the fiberglasser to have the sides redone as one was split and the laminate was peeling. just got it back this arvo and I'm trying to fit it but nothing lines up. I'm assuming maruti didn't use pop rivets to hold the mounts on and that someone else has done this. One side is alright but the other is about 50mm out, I think the bracket is to short. I shelled out and purchased suzuki latches from suzi store but again the front hardware in the top must be someones bodge job because with the maruti latches that I bought the top is held down more when they are open than closed. Even then I would not trust the fit to drive down the highway with it like that. Can anyone shed some light on what hardware is supposed to be connected to the top, or what I need to get to fit this properly?
Just a bit frustrated because I dropped $700 on this front section and currently a $10 piece of ply would probably do a better job.
Thanks everyone
Rossco
Post Posted: Fri Feb 22, 2013 4:10 pm
I have found the hardware that attaches to the roof from suzi store, the roof hook. I think I will order two more latches and four hooks. Does anyone have a picture of the stock roof setup? google hasn't yielded anything useful.
Vehicle: '94 suzuki maruti
Post Posted: Fri Feb 22, 2013 4:48 pm
take a look at this thread, i put photos of all the mounts...
viewtopic.php?f=5&t=36998&hilit=maruti+roof
Post Posted: Fri Feb 22, 2013 5:15 pm
That's perfect thank you. Don't know how I missed that thread I searched all the key words I could think of.
Post Posted: Fri Feb 22, 2013 6:06 pm
took me a few goes and i knew which thread i was looking for haha
Post Posted: Fri Feb 22, 2013 8:46 pm
hey whincup I see that your roof has a raised section to mount the roof hook to, mine doesn't have one, its just flat. You reckon I can mount the hook with a spacer of some sort and a screw? I think that might tear out through the fiberglass if pressure was put on it for a long time.
Post Posted: Fri Feb 22, 2013 10:29 pm
i dont think thats a factory maruit roof.. its defiantly different to my old one.
Post Posted: Fri Feb 22, 2013 10:52 pm
don't the maruti roofs have a smooth gel coat on the outside, rather than the leather textured finish that the flexiglass/tjm etc ones have?
Post Posted: Fri Feb 22, 2013 11:26 pm
Definately NOT a Maruti top.
And yes the Maruti has a textured finish.
Post Posted: Sat Feb 23, 2013 8:35 am
hmm good info guys. This one has a smooth finish. The only defining feature is there is an undamaged patch in the gel coat in the middle of the front where a label used to be. Its about 30x20 mm. It sits in the rear groove of the b-piller like the flexiglass flavor roofs. Here are some pictures of the top of the roof that may help in identification.
Post Posted: Sat Feb 23, 2013 9:30 pm
Yeah thats noy like any maruti top I've ever seen.
Never the less, it will work just the same.
Users browsing this forum: Google [Bot] and 41 guests
