It is currently Tue Oct 20, 2026 12:57 pm
Vehicle: 1997 Sierra SJ80
Post Posted: Fri Feb 22, 2013 7:46 pm
I been trying to find a place that has key blanks for the Sierra. The local bunnings, hardware, and shopping centre didn't have the right blanks.
I went to the Locksmiths only to find they have closed down.
So I went back to the hardware shop, (cause I know the owner reasonably well) and searched through his collection.
Found that a Hyundai key matched. (HYN10)
Also found a GM key, but the head of the key has to be ground a bit, as it wouldn't allow the key to be removed from the ignition.
Vehicle: Suzuki Grand Vitara
Post Posted: Fri Feb 22, 2013 7:58 pm
http://www.ebay.com.au/itm/SUZUKI-JIMNY ... 2c6a2648b4
Post Posted: Fri Feb 22, 2013 7:59 pm
I got my last Sierra key cut at Bunnings?
Vehicle: Clown Car..
Post Posted: Fri Feb 22, 2013 8:02 pm
http://www.suzuki-forums.com/suzuki-jim ... ade-2.html
Helpful?? Top post... maybe a Paj key will work!?
Post Posted: Fri Feb 22, 2013 8:08 pm
my apprentice used to have a holden gemini, and my sierra key would unlock his doors and start the ignition! The keys were almost identical - his didnt work on my sierra though.
Post Posted: Fri Feb 22, 2013 8:13 pm
That would have more to do with a stuffed tumbler in the gemi then matching keys :wink: My old Navara you could push the centre part in and turn it with your finger to start it up.
Post Posted: Fri Feb 22, 2013 8:27 pm
yeah for sure - but holding the keys next to each other they were also very close.
Post Posted: Fri Feb 22, 2013 10:29 pm
Tried Bunnings a couple times, over the last month or so.
They had Suzi keys, but they will only match the code, so if they don't have THAT code blank, they turn ya away.
I should have said in the OP, that I wanted to get a spare actually cut, not just get a blank. finding the blank was the hard part.(wasn't trying to make a bump key for a zook!)
Coulda bought an ebay one, but was trying to go local..
yeah, and we all know a dipstick will start an early Falcon...
Post Posted: Sat Feb 23, 2013 9:22 am
The NT and WT key profile is different, not sure what the go with the coily is, but as per every other part of a Sierra, nothing fits a coily :thefinger:
Post Posted: Sat Feb 23, 2013 12:05 pm
Now that I have my keys back, I can post the codes...
The "original" key, which is a copy, is SZ12
The Hyundai key is (as above) a HYN10,
and the GM key is a GM11, but as I said, the corners of the key head have to be ground to clear the ignition bezel.
Users browsing this forum: No registered users and 185 guests
