It is currently Fri Sep 25, 2026 6:46 am
Vehicle: 1994 Suzuki Sierra 1.3
Post Posted: Sat Feb 23, 2013 9:39 pm
My Sierra has just started making a squeaking noise when ever
I take my foot off the accelerator. I push the accelerator and the
Noise goes away. It doesn't make the noise at idle either.
Does anyone know what it could be?
Skelly
Post Posted: Sat Feb 23, 2013 11:00 pm
is it related to the wheel speed, or just random??
if its related to wheel speed, could be worn brakes or something in the brakes, mayyybe wheel bearings.
if its random, could be worn bushes in the leaves, or the leaves themselves squeaking.
Post Posted: Sun Feb 24, 2013 6:58 am
Worn or broken engine/gearbox/transfer mounts is a possibility, too.
A loose exhaust could do it, too.
Try to get a taping of the noise for people with good ears to help you.
Post Posted: Sun Feb 24, 2013 7:49 am
It's going to be hard to record a noise because
It only happens when driving. The noise sounds
Similar to when you run on a indoor basket ball
Court and it makes that squeking noise when you
Are wearing joggers
Post Posted: Sun Feb 24, 2013 8:01 am
Dry Uni joint?
Post Posted: Sun Feb 24, 2013 8:03 am
yeah does it do it in reverse?
Post Posted: Sun Feb 24, 2013 8:06 am
Give us an idea of where the noise is coming from, front, middle or rear. So far it could be anything
Post Posted: Sun Feb 24, 2013 8:38 am
Front
Post Posted: Sun Feb 24, 2013 8:49 pm
Uni for sure...
Post Posted: Sun Feb 24, 2013 9:22 pm
want33s wrote:
Uni for sure...
I've checked the Uni joints there is play on any
Of them. Could they be dry?
Post Posted: Sun Feb 24, 2013 9:27 pm
uni joints can sieze on one axis, without showing any play.
Is uni joint getting hot? Particularly on one axis
Post Posted: Sun Feb 24, 2013 9:35 pm
Don't know I will have to check. Is there a specific
Uni I should be looking at? There are a few under there.
Post Posted: Sun Feb 24, 2013 9:38 pm
The rear rear gets most use, but check all.
Be careful, I burn't my fingers checking mine once
Post Posted: Sun Feb 24, 2013 9:39 pm
Ok thanks heaps for that
Post Posted: Mon Feb 25, 2013 6:34 am
Another one to check if it squeeks when driving only is the speddo cable. My sierra had an annoying as hell squeek when driving and it was the cable. $10 for one off ebay and its is a 10 minute fix.
Dave
Users browsing this forum: No registered users and 132 guests
