http://auszookers.com/forum/
Sierra squeeking
http://auszookers.com/forum/viewtopic.php?f=5&t=39183
Author:  skelly [ Sat Feb 23, 2013 9:39 pm ]
Post subject:  Sierra squeeking
My Sierra has just started making a squeaking noise when ever
I take my foot off the accelerator. I push the accelerator and the
Noise goes away. It doesn't make the noise at idle either.
Does anyone know what it could be?
Skelly
Author:  alien [ Sat Feb 23, 2013 11:00 pm ]
Post subject:  Re: Sierra squeeking
is it related to the wheel speed, or just random??
if its related to wheel speed, could be worn brakes or something in the brakes, mayyybe wheel bearings.
if its random, could be worn bushes in the leaves, or the leaves themselves squeaking.
Author:  christover1 [ Sun Feb 24, 2013 6:58 am ]
Worn or broken engine/gearbox/transfer mounts is a possibility, too.
A loose exhaust could do it, too.
Try to get a taping of the noise for people with good ears to help you.
Author:  skelly [ Sun Feb 24, 2013 7:49 am ]
It's going to be hard to record a noise because
It only happens when driving. The noise sounds
Similar to when you run on a indoor basket ball
Court and it makes that squeking noise when you
Are wearing joggers
Author:  Bruce [ Sun Feb 24, 2013 8:01 am ]
Dry Uni joint?
Author:  royce [ Sun Feb 24, 2013 8:03 am ]
yeah does it do it in reverse?
Author:  Scrawny [ Sun Feb 24, 2013 8:06 am ]
Give us an idea of where the noise is coming from, front, middle or rear. So far it could be anything
Author:  skelly [ Sun Feb 24, 2013 8:38 am ]
Front
Author:  want33s [ Sun Feb 24, 2013 8:49 pm ]
Uni for sure...
Author:  skelly [ Sun Feb 24, 2013 9:22 pm ]
want33s wrote:
Uni for sure...
I've checked the Uni joints there is play on any
Of them. Could they be dry?
Author:  christover1 [ Sun Feb 24, 2013 9:27 pm ]
uni joints can sieze on one axis, without showing any play.
Is uni joint getting hot? Particularly on one axis
Author:  skelly [ Sun Feb 24, 2013 9:35 pm ]
Don't know I will have to check. Is there a specific
Uni I should be looking at? There are a few under there.
Author:  christover1 [ Sun Feb 24, 2013 9:38 pm ]
The rear rear gets most use, but check all.
Be careful, I burn't my fingers checking mine once
Author:  skelly [ Sun Feb 24, 2013 9:39 pm ]
Ok thanks heaps for that
Author:  bohuler [ Mon Feb 25, 2013 6:34 am ]
Another one to check if it squeeks when driving only is the speddo cable. My sierra had an annoying as hell squeek when driving and it was the cable. $10 for one off ebay and its is a 10 minute fix.
Dave
