| Knocking sound sierra http://auszookers.com/forum/viewtopic.php?f=5&t=39210 |
| Author: | skelly [ Sun Feb 24, 2013 8:38 pm ] |
| Post subject: | Knocking sound sierra |
My Sierra makes a knocking sound when I'm stopped in nuetral With the clutch out. When I push the clutch in it goes away. Does anyone know what it could be? Skelly |
| Author: | want33s [ Sun Feb 24, 2013 8:41 pm ] |
| Post subject: | Re: Knocking sound sierra |
Input shaft bearing in the gearbox. Bearing kits are available from Weaves or full rebuild kits from Lowrangeoffroad. |
| Author: | skelly [ Sun Feb 24, 2013 8:45 pm ] |
want33s wrote: Input shaft bearing in the gearbox. Bearing kits are available from Weaves or full rebuild kits from Lowrangeoffroad. How long can I get away with this because in in the process of Rebuilding a new motor for the zook and should be done In 4 weeks |
| Author: | want33s [ Sun Feb 24, 2013 8:47 pm ] |
It'll last longer than you can stand the noise. |
| Author: | skelly [ Sun Feb 24, 2013 8:52 pm ] |
want33s wrote: It'll last longer than you can stand the noise. Is it an easy thing to replace once the gearbox is dropped? |
| Author: | want33s [ Mon Feb 25, 2013 6:22 am ] |
skelly wrote: Is it an easy thing to replace once the gearbox is dropped? Not really... It means a full rebuild of the gearbox but having said that, 1.3 Sierra 5 speeds are the simplest gearbox I've ever opened. |
