It is currently Sat Sep 26, 2026 4:20 am
Vehicle: 91 vitara swb
Post Posted: Mon Feb 25, 2013 4:44 pm
ive looked around for threads but cant find much
is there a code on the car you can look for like toyotas?
or does it just go on what year your car is cause i found that thread?
and would rear and front be the same or what?
Post Posted: Mon Feb 25, 2013 4:48 pm
front and rear are different.
and yes generally its down to the year
and where it is an auto or manual
I assume you are talking about ratios?
Year, model, engine, transmission. Should be able to help you then.
Post Posted: Mon Feb 25, 2013 4:57 pm
1991 1.6 carby manual so im assuming 5.375
how can you tell about front ratio?
Post Posted: Mon Feb 25, 2013 5:00 pm
5.12:1 & it's the same ratio front & back... the actual sizes of the diffs differ. :wink:
Post Posted: Mon Feb 25, 2013 5:03 pm
might be noob qn but fo you mean housings are dif sizes or actual centers? so u cant put a rear diff center in a front housng?
Post Posted: Mon Feb 25, 2013 5:05 pm
they are completely different, you can use 2 vitara front's to re-gear a sierra though. :wink:
Post Posted: Mon Feb 25, 2013 5:08 pm
lol. just still trying to find a simple upgrade for mine. if its 5.12 for rear thats fairly tight its just the front i need to replace.
Post Posted: Mon Feb 25, 2013 5:10 pm
there is no "simple" upgrades 5.12's are as good as it gets in regards to diff gears without spending mega $$$$'s
what are you wanting/trying to do?
Post Posted: Mon Feb 25, 2013 5:15 pm
just like in my previous threads taht my front seems really loose and doesnt like sand etc and mainly needs the left wheel to spin in order the right one to spin
Post Posted: Mon Feb 25, 2013 5:18 pm
so its singleing? thsts because its not an lsd/locker so basically only one will ever spin.
or am I on the wrong track?
Post Posted: Mon Feb 25, 2013 5:25 pm
it's an open diff so power will go to the path of least resistance, does it mainly happen when bogged/almost bogged?
Post Posted: Mon Feb 25, 2013 5:28 pm
well before happened as soon as i hit sand. dirt it seems to be ok but could be better
Post Posted: Mon Feb 25, 2013 5:30 pm
are you 100% sure your free wheeling hubs are working properly & aren't seized/sticking?
my vitara absolutely owns the sand with low tyre pressures.... as in it's almost unboggable.
Post Posted: Mon Feb 25, 2013 5:34 pm
wen i got ther car they were seized, got them greased up so they would lock in 4x4 mode
Post Posted: Mon Feb 25, 2013 6:28 pm
Sure you put the hubs back right?
You have an open diff. Replacing it with another open diff won't make it any better. One wheel will spin. That's what happens. You'll only spin both wheels if they both have exactly equal traction. That almost never happens.
Steve
Post Posted: Mon Feb 25, 2013 7:08 pm
Steve
ie if theyre in the air :rofl:
Users browsing this forum: No registered users and 110 guests
