It is currently Fri Sep 25, 2026 2:14 am
Post Posted: Sun Feb 24, 2013 4:33 pm
If anyone is still looking for someone who can rebuild LJ50 crank shafts I know some one who can do it for $120 labour if you supply the parts and I know where to get them as well.
Post Posted: Sun Feb 24, 2013 7:33 pm
:D :D Awesome.
Post Posted: Mon Feb 25, 2013 1:42 pm
now just need to find crank bearings
Vehicle: 85 ' Drover
Post Posted: Mon Feb 25, 2013 1:53 pm
How does one rebuild a crankshaft?
Post Posted: Mon Feb 25, 2013 2:00 pm
in an LJ50 they are made in multiple peices and pressed together with the bearings and conrods in place.
Post Posted: Mon Feb 25, 2013 2:33 pm
Only the one with the groove is a problem and that is not in the pressed together section.
Post Posted: Mon Feb 25, 2013 2:58 pm
most of the bearings have the roll pins in them. what do you replace them with?
Post Posted: Mon Feb 25, 2013 3:03 pm
The 2 bearings on the crank with the pins are just to stop the outer race slipping in the casing and bearing lock-tight will do the same thing.
Post Posted: Mon Feb 25, 2013 3:39 pm
If you really want the roll pins in the bearings, go find a friendly toolmaker with a plunge EDM.
The bearings will need to be sealed up well but it isn't a big job to burn some holes into the bearing.
Post Posted: Mon Feb 25, 2013 4:09 pm
Don't know how to insert a YouTube so here's a link - http://www.youtube.com/watch?v=Z5WZqYl_aZ8
Users browsing this forum: Google [Bot] and 148 guests
