It is currently Fri Sep 25, 2026 1:18 am
Vehicle: Twin cam 1300 gti engine.
Post Posted: Mon Feb 25, 2013 6:14 pm
I'm after what the title says. Searched google and couldn't find anything I could use.
Thanks a lot in advance.
Post Posted: Mon Feb 25, 2013 6:19 pm
What gasket are you using? Normally the torque and sequence is printed on the packaging
Post Posted: Mon Feb 25, 2013 6:55 pm
Yer just a normal one mate. Bought a full vrs kit but it doesn't have any info on the torque settings.
Post Posted: Mon Feb 25, 2013 6:58 pm
I did mine a few weeks ago, might still have the specs in the shed. Will have a look shortly
Post Posted: Mon Feb 25, 2013 7:21 pm
I can't find the gaskit instructions but had a look in my factory manual.
Head bolts are 47 to 50.5 flb. Torqued up in 3 stages so 20 then 35 then 50flb. Centre 2 bolts first then alternate bolts either side of the first two and finishing with the outside bolts last. Tighten all bolts before cranking the torque wrench up to the next step
Hope this makes sense, my GTI motor has had a head stud conversion so I did 4 steps and finished up at 70 flb.
Users browsing this forum: Google [Bot] and 132 guests
