It is currently Fri Sep 25, 2026 9:06 am
Post Posted: Tue Feb 26, 2013 10:15 am
It seems my offroad adventure has taken its toll on the XL-7.
it developed a rather bad rattle from the back door... I came home pulled the rear surround off and it has cracked the rear door..
So my question is where the heck do I find a New barn door ?
Will the door from a Normal Grand Vitara fit ??
Vehicle: 2002 Suzuki XL7
Post Posted: Tue Feb 26, 2013 11:09 am
where did it crack? is the spare tyre size on rear standard or larger?
Post Posted: Tue Feb 26, 2013 11:15 am
pics, where has it cracked, the outer skin or some of the bracing on the inside or the inner skin?
cracks can be easily dealt with by a decent panel shop, drill a small hole at each end of the crack to stop it spreading & weld it all up. the holes stop the crack spreading as it reduces the stress risers caused by the crack.
do the GV's/XL-7's run the round adjustable door stop/support on the tail gate?
Post Posted: Tue Feb 26, 2013 11:22 am
Inside of the Door Skin.. Right below the centre of the rear window..
I will get pics up as soon as I can..
Post Posted: Tue Feb 26, 2013 12:01 pm
Yeah it needs to be replaced the Panel is cracked pretty badly.. To the point where the rear window is the only thing keeping the door rigid...
Post Posted: Tue Feb 26, 2013 12:06 pm
PICS :roll:
didn't this thing have one of the door skin replaced, wonder if it's been in a reasonable crash & they reskinned the tail gate too?
Post Posted: Tue Feb 26, 2013 12:25 pm
The Arrows indicate the cracks..
Post Posted: Tue Feb 26, 2013 12:30 pm
8O thats not good, got any close ups of the cracks?
Post Posted: Tue Feb 26, 2013 1:54 pm
bottom crack
Top crack
Post Posted: Tue Feb 26, 2013 2:40 pm
Whoa that copped a hit! Is that a crease at the very top of the door in the outside pic?
Post Posted: Tue Feb 26, 2013 3:11 pm
Do you think they backed into a wall with the Spare tyre to cause that ?
I re-checked the door the top lip is actually straight
Post Posted: Tue Feb 26, 2013 3:18 pm
yeah something like that or being rear-ended, looks like a reasonable hit.
a load of bog & some paint would cover up the dents on the outside, as i said before if they've re-skinned one door i'd be 2nd guessing the rest of the car.
Vehicle: Drover pickup turk
Post Posted: Tue Feb 26, 2013 5:04 pm
Is it just me or does the top crack have some mismatched paint around it?
I like the tuna here
Post Posted: Tue Feb 26, 2013 5:07 pm
yeah i noticed that as well & have a look at the damage around the area of the lower crack, it's taken a fair old knock.
Post Posted: Tue Feb 26, 2013 5:27 pm
Ah the joys of finding stuff AFTER you have bought it... I mean the Vehicle Inspector reported a door Rattle and suggested it was the locking mechanism..
I just checked it again via carhistory.com.au and it has indeed had no reported Insurance claims..
Post Posted: Tue Feb 26, 2013 5:33 pm
Would be worth pulling the rear bumper off and checking the rear crossmember/bumper support bar for damage. Cross member isn't something they can easily just patch over so should be pretty evident if its been in a major bingle.
If crossmember shows no sign of damage, I say replace the barn door, forget about it and enjoy the car :)
Post Posted: Tue Feb 26, 2013 5:37 pm
No damage to bumper or Re-inforcement bar.. Not even a scratch I am going to have to go with they backed into something and the tyre took the brunt of it..
I am more then happy to replace the rear door... IF I can find one some where... I still need to find out if the GV Door fits or do I have to specifically hunt down an XL-7 door..
Post Posted: Tue Feb 26, 2013 5:46 pm
pretty sure you'd have to pull the plastic bumper cover off to see if the bumper reo or the crossmember is bent.
Post Posted: Tue Feb 26, 2013 7:19 pm
Door Hunt is on... Where is the best place to look ???
Post Posted: Tue Feb 26, 2013 7:27 pm
Wreckers if you want a quick replacement and are prepared to spend the $$. Failing that, scour gumtree for someone wrecking one privately if you can wait a little while. Should be able to pick one up for stuff all that way.
Stuffed if I know where they are in relation to you, but I highly recommend New Model Wreckers (http://www.newmodelwreckers.com.au). Avo who works there is on the ball, and they are definitely one of the better wreckers I've dealt with. As a bonus they are almost always the cheapest as well (often being half the price of others).
Post Posted: Tue Feb 26, 2013 7:37 pm
$770 for a Silver one..
Post Posted: Wed Feb 27, 2013 2:57 pm
New door sourced for $100... OK its Green but I can live with that... All I have to do is mount the spare tyre carrier, swap the Key locks over, Allign and fit..
Vehicle: 95 SJ70, 96 Escudo v6
Post Posted: Fri Mar 01, 2013 5:50 pm
I backed into a van with my sierra/samuari bent the door a bit but nothing like that! I just have to slam it slightly and its fine, been 6-7 years like that now.
Post Posted: Sat Mar 02, 2013 5:37 am
Its all good... Found a door on Trading post for $100... fitted it... and it now closes with authority and not a half baked tinny wobble..
Users browsing this forum: Google [Bot] and 130 guests
