| Barn Door Replacement http://auszookers.com/forum/viewtopic.php?f=5&t=39250 |
| Author: | magnat [ Tue Feb 26, 2013 10:15 am ] |
| Post subject: | Barn Door Replacement |
It seems my offroad adventure has taken its toll on the XL-7. it developed a rather bad rattle from the back door... I came home pulled the rear surround off and it has cracked the rear door.. So my question is where the heck do I find a New barn door ? Will the door from a Normal Grand Vitara fit ?? |
| Author: | GeckoXL7 [ Tue Feb 26, 2013 11:09 am ] |
| Post subject: | Re: Barn Door Replacement |
where did it crack? is the spare tyre size on rear standard or larger? |
| Author: | atari4x4 [ Tue Feb 26, 2013 11:15 am ] |
pics, where has it cracked, the outer skin or some of the bracing on the inside or the inner skin? cracks can be easily dealt with by a decent panel shop, drill a small hole at each end of the crack to stop it spreading & weld it all up. the holes stop the crack spreading as it reduces the stress risers caused by the crack. do the GV's/XL-7's run the round adjustable door stop/support on the tail gate? |
| Author: | magnat [ Tue Feb 26, 2013 11:22 am ] |
Inside of the Door Skin.. Right below the centre of the rear window.. I will get pics up as soon as I can.. |
| Author: | magnat [ Tue Feb 26, 2013 12:01 pm ] |
Yeah it needs to be replaced the Panel is cracked pretty badly.. To the point where the rear window is the only thing keeping the door rigid... |
| Author: | atari4x4 [ Tue Feb 26, 2013 12:06 pm ] |
PICS didn't this thing have one of the door skin replaced, wonder if it's been in a reasonable crash & they reskinned the tail gate too? |
| Author: | magnat [ Tue Feb 26, 2013 12:25 pm ] |
![]() The Arrows indicate the cracks.. |
| Author: | atari4x4 [ Tue Feb 26, 2013 12:30 pm ] |
| Author: | magnat [ Tue Feb 26, 2013 1:54 pm ] |
![]() bottom crack ![]() Top crack |
| Author: | Chop [ Tue Feb 26, 2013 2:40 pm ] |
Whoa that copped a hit! Is that a crease at the very top of the door in the outside pic? |
| Author: | magnat [ Tue Feb 26, 2013 3:11 pm ] |
Do you think they backed into a wall with the Spare tyre to cause that ? I re-checked the door the top lip is actually straight |
| Author: | atari4x4 [ Tue Feb 26, 2013 3:18 pm ] |
magnat wrote: Do you think they backed into a wall with the Spare tyre to cause that ? I re-checked the door the top lip is actually straight yeah something like that or being rear-ended, looks like a reasonable hit. a load of bog & some paint would cover up the dents on the outside, as i said before if they've re-skinned one door i'd be 2nd guessing the rest of the car. |
| Author: | Blkfxx [ Tue Feb 26, 2013 5:04 pm ] |
Is it just me or does the top crack have some mismatched paint around it? |
| Author: | atari4x4 [ Tue Feb 26, 2013 5:07 pm ] |
yeah i noticed that as well & have a look at the damage around the area of the lower crack, it's taken a fair old knock. |
| Author: | magnat [ Tue Feb 26, 2013 5:27 pm ] |
Ah the joys of finding stuff AFTER you have bought it... I mean the Vehicle Inspector reported a door Rattle and suggested it was the locking mechanism.. I just checked it again via carhistory.com.au and it has indeed had no reported Insurance claims.. |
| Author: | ninjamoses [ Tue Feb 26, 2013 5:33 pm ] |
Would be worth pulling the rear bumper off and checking the rear crossmember/bumper support bar for damage. Cross member isn't something they can easily just patch over so should be pretty evident if its been in a major bingle. If crossmember shows no sign of damage, I say replace the barn door, forget about it and enjoy the car |
| Author: | magnat [ Tue Feb 26, 2013 5:37 pm ] |
No damage to bumper or Re-inforcement bar.. Not even a scratch I am going to have to go with they backed into something and the tyre took the brunt of it.. I am more then happy to replace the rear door... IF I can find one some where... I still need to find out if the GV Door fits or do I have to specifically hunt down an XL-7 door.. |
| Author: | atari4x4 [ Tue Feb 26, 2013 5:46 pm ] |
pretty sure you'd have to pull the plastic bumper cover off to see if the bumper reo or the crossmember is bent. |
| Author: | magnat [ Tue Feb 26, 2013 7:19 pm ] |
Door Hunt is on... Where is the best place to look ??? |
| Author: | ninjamoses [ Tue Feb 26, 2013 7:27 pm ] |
Wreckers if you want a quick replacement and are prepared to spend the $$. Failing that, scour gumtree for someone wrecking one privately if you can wait a little while. Should be able to pick one up for stuff all that way. Stuffed if I know where they are in relation to you, but I highly recommend New Model Wreckers (http://www.newmodelwreckers.com.au). Avo who works there is on the ball, and they are definitely one of the better wreckers I've dealt with. As a bonus they are almost always the cheapest as well (often being half the price of others). |
| Author: | magnat [ Tue Feb 26, 2013 7:37 pm ] |
$770 for a Silver one.. |
| Author: | magnat [ Wed Feb 27, 2013 2:57 pm ] |
New door sourced for $100... OK its Green but I can live with that... All I have to do is mount the spare tyre carrier, swap the Key locks over, Allign and fit.. |
| Author: | Pooke [ Fri Mar 01, 2013 5:50 pm ] |
I backed into a van with my sierra/samuari bent the door a bit but nothing like that! I just have to slam it slightly and its fine, been 6-7 years like that now. |
| Author: | magnat [ Sat Mar 02, 2013 5:37 am ] |
Its all good... Found a door on Trading post for $100... fitted it... and it now closes with authority and not a half baked tinny wobble.. |
