It is currently Fri Sep 25, 2026 1:59 pm
Vehicle: Suzuki Vitara JLX 1991
Post Posted: Fri Mar 01, 2013 7:10 am
Hi guys I have a squeaky belt which is on the right hand side. I'm going to replace all the Belts. What I can see is 2 belts.
Anyine know part numbers for a 1991 vitara jlx SWB?
Might as well do then all now just in case as I'm not aware of their age as I have only had the vehicle for 6 months.
Vehicle: 85 ' Drover
Post Posted: Fri Mar 01, 2013 8:21 am
hey mate,
just have a look on the belt itself, there will be a few numbers, they describe the belt.
ie 4pk650, is a belt with 4 grooves in it and is 650mm long. 5pk 600 is 5 grooves and 600mm long. etc.
the belts that dont have grooves have a slightly different numbering system, not sure what it is, but its written on the belt like the others.
Post Posted: Sat Mar 02, 2013 4:48 pm
and note that you can usually go a few numbers in either direction if you cant find the exact belt you are chasing.
I know i had to get a size smaller alternator belt and one larger for aircon.
MY BUILD THREAD HERE!!!!!
Users browsing this forum: No registered users and 68 guests
