It is currently Tue Nov 03, 2026 7:33 pm
Vehicle: 99 Grand Vitara
Post Posted: Thu Mar 07, 2013 9:21 am
Hey fellas,
Im getting a noise and vibration when driving straight or turning right.. When I turn left it goes away???? Was thinking a weight came off the rim, but ill find out when i put my muddies on this arvo. Anyone have any ideas of what it could be? It feels and sounds like its coming from the front but dad reckons its from the back.
http://www.strictly4x4.com.au
Post Posted: Thu Mar 07, 2013 9:30 am
there isnt nearly enough info here for anyone to help diagnose.
take a video of the sound and whack it up
Vehicle: 85 ' Drover
Post Posted: Thu Mar 07, 2013 9:44 am
klutched wrote:
Hey fellas,
Noise changing on loading and unloading of a wheel to me represents a damaged wheel bearing.
Post Posted: Thu Mar 07, 2013 10:14 am
Will get a vid this arvo.
@droverdave Wouldn't it be constant though??
exact same noise with teh exact same conditions, was the inner race of the front left wheel bearing
Post Posted: Thu Mar 07, 2013 10:26 am
Gaay... Should I replace both sides at the same time? What's a rough price to get it done?
Post Posted: Thu Mar 07, 2013 3:05 pm
you say its constant when you are driving straight, thats cause the weight on each wheel remains constant.
When you go around a corner, left, the left wheels get less weight, and the right wheels get more weight. so the noise changes.
hard to know exactly what side is what, but best to do them both at the same time.
I have the exact same thing, turns out to be my rear right wheel bearing. When i go around right corners it shuts up.
I have just purchsaed both wheel bearing kits (L and R) from "4wd_products" on ebay, was $69 for the bearings, axel seals and some spacer thing.
Bursons wanted $110 for the bearing kits.
I have to remove the axels and press the old bearings off, and the new bearings on. I have a small supercheap auto press, im not sure i will be able to press them off myself (press might be too short). might end up just taking them to the mechanic to do them. (ie i will remove the axels and take them to him)
If you are going to pay someone to do the whole lot, i would budget $300-400.
Users browsing this forum: Google [Bot] and 449 guests
