| Author |
Message |
Rye_Bread
Joined: Tue Jul 17, 2012 9:42 pm Posts: 41 Location: sunshine coast
Vehicle: Suzuki Sierra SWB Soft-top
 Posted: Sun Mar 10, 2013 5:48 pm |
Hey everyone! I want to get reduction gears for my 1991 sierra and was wondering what reduction I should get and where I can find some in Australia? I'm running 31x10.5r15 mud terrain and I have a 1.3 gti EFI motor.. I go 4wding all most every weekend and its also my daily car... Cheers
303zuke
Vehicle: LJ50V, SJ70
 Posted: Sun Mar 10, 2013 7:40 pm |
You would have 3 suitable choices: 4.9s or 5.14s from the States. Lowrange Offroad offer both at probably the cheapest you'd find, or 5.25s from TrialJimnyEach of those progressively go from cheapest to most expensive, but in the same order from least to most useful.
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Sun Mar 10, 2013 8:01 pm |
As above. Depends on terrain though.
4.9, 5.14, the 5.25 mentioned and 6.5's are all options.
Personally 5.14 and 6.5's are my pick.
_________________ mlm
appsie
 Posted: Sun Mar 10, 2013 9:30 pm |
i had and loved 6.5s with my 31s with both a 1.3 carb and 1.6 efi. least having the gti engine you know it loves to rev
Rye_Bread
 Posted: Sun Mar 10, 2013 9:53 pm |
appsie wrote: i had and loved 6.5s with my 31s with both a 1.3 carb and 1.6 efi. least having the gti engine you know it loves to rev  Hahaha so true!
its u its me
Joined: Mon Feb 18, 2013 7:31 am Posts: 110 Location: Calgary AB Canada
Vehicle: Suzuki Sierra 1994 Soft Top
 Posted: Mon Mar 11, 2013 11:14 am |
This is a good question, I am to running 31"s and will also be looking at reduction gears over the next couple of months.
Are most people running a transfer case support brace with reduction gears? or does the standard housing hold up ok? I note a few companies are selling these and stating a "must have" item with gears.
tanshi
Joined: Tue Jan 09, 2007 10:30 pm Posts: 7717 Location: Brisbane
 Posted: Mon Mar 11, 2013 11:17 am |
if you have gears, you really should have a rock toy ring.
big gears like 6.5s will tear cases in half without it.
its u its me
 Posted: Mon Mar 11, 2013 11:53 am |
tanshi
 Posted: Mon Mar 11, 2013 11:58 am |
yep, they will need to be welded to arms though.
they are designed to be just part of a custom mount for the trasnfer
SierraDan
 Posted: Mon Mar 11, 2013 12:04 pm |
I've never run a ring. Only braced arms. Without issue. Not to say it isn't something good to buy and I will be getting one, but it's not necessary.
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Mon Mar 11, 2013 5:19 pm |
SierraDan wrote: I've never run a ring. Only braced arms. Without issue. ..................... it's not necessary. X2..
Gwagensteve
 Posted: Tue Mar 12, 2013 7:53 am |
tanshi
 Posted: Tue Mar 12, 2013 8:02 am |
never said you had to. i said you should. its cheep insurance
want33s
 Posted: Tue Mar 12, 2013 5:40 pm |
tanshi wrote: never said you had to. i said you should. its cheep insurance I crash landed my whole car on the transfer(onto rock) several times, broke a few "Unbreakable" ROCK4X poly mounts, bent the shifter inside the transfer from the transfer coming up against the floor, shattered quite a few rear uni joints and destroyed god knows how many leaf springs through clutch dumping axle wrap but never had so much as a drop of oil leak out of the transfer.
jimbo_jones
Joined: Sat Jul 19, 2008 11:30 pm Posts: 4361 Location: gong
 Posted: Wed Mar 13, 2013 6:14 pm |
I have 31's with 6.5 gears and love it I wouldnt get any other gears for what I drive. What type of 4wding do you do?
Rye_Bread
 Posted: Wed Mar 13, 2013 9:25 pm |
jimbo_jones wrote: I have 31's with 6.5 gears and love it I wouldnt get any other gears for what I drive. What type of 4wding do you do? a bit of everything but none of the really extreme stuff
TryHard
Joined: Thu May 13, 2010 1:49 am Posts: 1041 Location: Perth
 Posted: Wed Mar 13, 2013 10:20 pm |
Cheap option run a 1lt case won't that work for some reduction
TryHard
 Posted: Wed Mar 13, 2013 10:23 pm |
want33s wrote: SierraDan wrote: I've never run a ring. Only braced arms. Without issue. ..................... it's not necessary. X2.. X4 put mightykongskid
jdk81
Joined: Sat Jul 18, 2009 11:30 pm Posts: 2372 Location: Ballarat, VIC
 Posted: Thu Mar 14, 2013 12:08 am |
I had 6.4s for a long time without a cradle/ring etc but drove carefully, once I put the cradle on, I punished my car. I recently chewed a set of gears apart whilst driving down the highway. It was the hottest day this summer, and a long drive towing a trailer. From inspection it looks like it had failed over a period of time.
If buying new, I would only buy the 6.5s (solely for the lifetime warranty). Low 1st is too low for most uses, but the cost of a new set of gears helps me justify the annoyance.
If buying second hand (even if they are new, but someone else bought and hasn't installed yet, it would need to be cheap). If the manufacturers warranty is expired or nontransferable, I wouldnt pay new or near new prices.
The BenT xfer arms looks like a decent option.
TryHard
 Posted: Thu Mar 14, 2013 12:16 am |
Rye_Bread wrote: jimbo_jones wrote: I have 31's with 6.5 gears and love it I wouldnt get any other gears for what I drive. What type of 4wding do you do? a bit of everything but none of the really extreme stuff Don't get me wrong i love my 6.5 for the rocks etc but far far to low for beach I hate driving on beach with them I just put a 1 lt case in slightly lower then the 1.3 case from what I read Or just buy a slighty higher set for allrounder
SierraDan
 Posted: Thu Mar 14, 2013 3:36 am |
TryHard wrote: want33s wrote: SierraDan wrote: I've never run a ring. Only braced arms. Without issue. ..................... it's not necessary. X2.. X4 put mightykongskid x5 $2 worth of steel
