It is currently Thu Oct 01, 2026 10:35 pm
Post Posted: Fri Mar 15, 2013 5:25 pm
I've had my baleno motor running for about 2 weeks now driving it everyday to and from work it seems to use a fare bit of fuel and you can smell the fuel when you give it a bit on the road.
For some reason the motor is fueling up and the idle is very low so low that when cold it stalls I had to bump it up by adjusting the throttle stop to get the idle up a it but would really like to know how to stop it fueling up
E dry thing like the vss is conected I still have to connect the check engine light
 Profile YIM
Post Posted: Fri Mar 15, 2013 6:08 pm
Sounds like the oxygen sensor could be on the way out. Would explain the increase in fuel consumption and a rough idle.
Post Posted: Fri Mar 15, 2013 6:20 pm
How do I get codes out of the computer if I hook up the check engine light can you flash it like the vn commodore
 Profile YIM
Vehicle: SWB Sierra
Post Posted: Fri Mar 15, 2013 6:35 pm
http://www.rhinopower.org/diag/cel.html
Post Posted: Fri Mar 15, 2013 6:44 pm
That's a good link cheers Armsup
 Profile YIM
Users browsing this forum: Google [Bot] and 184 guests
