It is currently Sun Oct 04, 2026 11:16 am
Vehicle: 1997 Vitara 2.0
Post Posted: Sun Mar 17, 2013 4:48 pm
Hi guys,
I dont know if you lot know where to get 16" sunraysia style steel rims from here but i struggled. Maybe im not looking in the right pllaces but I found this site
http://www.4x4tyres.co.uk/grand-vitara-door-1997-to-2000/16inch-7inch-black-spoke-grand-vitara-door-1997-to-2000-steel-wheel-p-3909.html
4 rims $500 delivered to my door in WA.
Just thought id share incase others were searching for some.
Col
Post Posted: Sun Mar 17, 2013 4:53 pm
Thats a good find, but you do realise that XL-7s have 16X7 rims 5P offset, and GV's are 16X6.5 5P steel or alloy?
If you are planning weld on beadlocks no problem, neither OEM rim can accommodate them, but otherwise I reckon XL-7 or GV rims are the go.
Post Posted: Sun Mar 17, 2013 5:04 pm
So these rims will sit further towards the hub? by 5 as they have a 0 offset? would this cause problems?
wasn't planning on bead locks steve was looking purely looking because I think these black rims look better than the steel GV rims I have. just a taste thing really. For my own satisfaction on aesthetics they should be ok though right??
Col
Vehicle: 99 Grand Vitara
Post Posted: Sun Mar 17, 2013 5:15 pm
That's an alright price. If you go down to your local tyre shop they should be able to hook you up for 16x7 sunnys for around $115 ea I think I was quoted. That was in a -13 though.
0 Offset means that the rim will move out towards your arch 5mm over a +5 offset.
http://www.strictly4x4.com.au
Post Posted: Sun Mar 17, 2013 5:28 pm
I think the important point is that they're only 5mm different to what you've just ordered. 0 vs 5P It won't cause a problem per se if you're already running GV rims, but it's effectively $500 for a rim that's 1/2" wider.
Post Posted: Sun Mar 17, 2013 5:30 pm
I thought GV rims were 16x7?
Post Posted: Sun Mar 17, 2013 5:49 pm
I thought they were 16X6.5 (Steel) 16X7 (alloy).
Post Posted: Sun Mar 17, 2013 6:11 pm
Got ya steve! Not ordered them just yet, but i will do when i get a bit of cash. Hi-flow cat and 2" exhaust is being saved up for now, just thought id share what i found as I struggled to get them wheels.
@Klutched , I asked a few places around here, but couldnt get a solid 'yes' of any places in the 5x139 stud pattern...
Post Posted: Sun Mar 17, 2013 6:13 pm
Also in my findings I found where to get the spoiler with the light same as Joe's on his White LWB he had if anyone was interested. I thought it really set off the Vit from the rest! not cheap tho, $240 at your door.
Post Posted: Sun Mar 17, 2013 7:42 pm
I 100% know KING do one in a 16x7 sunny for zooks. Quoted $115 each from Jax quickfit
Vehicle: SWB Sierra
Post Posted: Sun Mar 17, 2013 8:14 pm
Dynamic and Gecko also do a 16x7 with 5x139.7 pcd. They really shouldn't be that hard to find.
Vehicle: 1984 NT High Top
Post Posted: Sun Mar 17, 2013 8:24 pm
I can also vouch for a king rim in 16x7.
Ordering some next week
Post Posted: Sun Mar 17, 2013 11:12 pm
Fair play lads, as I said I was probably looking in the wrong places :oops: ah well thought was there, just the wrong one haha!
Post Posted: Mon Mar 18, 2013 1:13 am
We had 16x7 steels on the LWB models, they tend to be quite sought after for Vits and Sammys as well because of the offset.
Edit: from what I can find its
16x6.5 with 10mm offset
16x7 with 25mm offset
so by my calculations they both stick out the same distance +/- a mm.
Users browsing this forum: Google [Bot] and 167 guests
