It is currently Sun Oct 04, 2026 12:19 pm
Vehicle: Suzuki sierra 1995 1.3
Post Posted: Sun Mar 17, 2013 5:00 pm
Hey guys making some diff breather with some hose and couple of fuel filters, jus curious to know what size hose I would need to slide over the male fitting coming out the diff thanks:)
Post Posted: Sun Mar 17, 2013 5:27 pm
try searching will find what your after alot quicker but have a look in here
viewtopic.php?f=1&t=6031
Post Posted: Sun Mar 17, 2013 5:57 pm
http://auszookers.com/forum/viewtopic.php?f=1&t=6031
If you listen to some of the dribble in there though, people will tell you garden hose is no good :roll: It lasted me 2 1/2 years before i replaced it :lol:
Post Posted: Sun Mar 17, 2013 6:03 pm
Garden hose is no good.
Rusho wrote:
If you listen to some of the dribble in there though, people will tell you garden hose is no good It lasted me ONLY 2 1/2 years 8O before i replaced it
I have 6 years on my fuel line breathers. I've swapped everything else on the car around them. They're still fine.
Maybe replacement diffs/rebuilds are free for you, but 2.5 years isn't long enough out of a breather for me.
Post Posted: Sun Mar 17, 2013 6:07 pm
I only took it off to do the front end..would have lasted lasted longer but I figured I had a spare 15meters left over, I would treat the girl to some new hose.
Alex....each to there own. You can tell from the first few comments how this thread will turn out :peaceout:
Post Posted: Sun Mar 17, 2013 7:50 pm
Thanks guys:) well I can get some silicone hose from work just don't want to bust the original off if I don't no what size hose I need! Thanks:)
Post Posted: Mon Mar 18, 2013 5:31 am
To answer your question 1/2inch hose will fit over the breather pipe once you pop the cap off.
alternatively you run a 1/8"bsp tap down the middle of the breather pipe and put a brass hosetail in of any size you like, or a pushlok air fitting and run nylon tube which is what I done.
Looks neat and tidy. Not dodgy and bulky like 1/2inch hose and garden hose.....
Post Posted: Mon Mar 18, 2013 8:39 am
and it probably only went off road twice, maybe three times in that period... use the right material & you'll probably never have to replace it at all.
Post Posted: Mon Mar 18, 2013 8:55 am
:kissmyarse: :thefinger:
Users browsing this forum: No registered users and 151 guests
