It is currently Sun Nov 15, 2026 5:56 am
Vehicle: 1996 zook with lift and tyres
Post Posted: Tue Aug 27, 2013 9:12 pm
Probably a bit of a noob question, but is this a straight swap? I'm looking for a neater finish to a conversion for a sierra
Post Posted: Tue Aug 27, 2013 9:48 pm
I think a jimny manifold is the best option, I believe it still has the thermostat at the front like a vitara motor. If you use a baleno manifold they run a different thermostat housing on the back of the head.
Post Posted: Tue Aug 27, 2013 10:06 pm
Ahh....righty. Cheers for that. I did read something to that effect after I posted this. Off to do some more shopping then :-)
Post Posted: Wed Aug 28, 2013 8:25 am
I reckon that's going to be a pain. There's going to be little or no commonality on sensors between the two manifolds- it's likely going to be quite a lash up to get it to work- they each run completely different computers. I understand the desire to loose the crossover pipe, but I think the hassle might not make it worth it.
I have looked at reversing the vitara plenum, but there no room for the afm if you do that.
I reckon if you want a baleno manifold, and a super neat engine bay then you need the baleno loom and ecu, with coil packs.
Users browsing this forum: Google [Bot] and 77 guests
