| Brake booster upgrade ? http://auszookers.com/forum/viewtopic.php?f=5&t=39650 |
| Author: | Mattszook [ Sun Mar 17, 2013 6:20 pm ] |
| Post subject: | Brake booster upgrade ? |
[list=][/list]Hey lads and girls just wondering wat brake master cly and booster upgrade people have done I have a 1.3 gti motor convershion in a 92 zook and hilux diffs and extended brake lines it disc front and bundy drum rear its all adjusted and bleed correct it stops but some time I need a bit more hold on a hill climb and my pedal is at the floor and still rolling little scary lol |
| Author: | mnemonix [ Sun Mar 17, 2013 6:34 pm ] |
| Post subject: | Re: Brake booster upgrade ? |
Vitara Master cylinder and subaru booster. I've upgrade my maruti from non boosted (1.0litre) master cyl, to sierra cyl and subaru booster. It's a phenomenal improvement. Google "bolt on subaru master cylinder upgrade". You should find a link to ZukWharrie that has the details. I don't believe the specifics are on AZ. |
| Author: | Red89 [ Sun Mar 17, 2013 7:21 pm ] |
The Subarau option was going to workout too expensive for my liking so I used a GQ MC which bolts straight to the Sierra booster. viewtopic.php?f=14&t=26923&hilit=+GQ+Master+cylinder |
| Author: | Mattszook [ Sun Mar 17, 2013 8:03 pm ] |
Cool that sounds good to me got heaps of mates with gq parts so that will work out well because I have drum in the rear should I go gq mc disc/ drum or just the disc one ? |
| Author: | Red89 [ Sun Mar 17, 2013 8:27 pm ] |
I went disc/disc because Ive got a disc all round, it works really well in my setup. I dont have any experience with the disc/drum model sorry, it is a 1 inch bore which is bigger then the Sierra one so should be an upgrade for it. |
| Author: | Mattszook [ Sun Mar 17, 2013 8:54 pm ] |
Well I have a disc/drum one at my mates for free so I will put it in and let u know if it's better cheers mate |
| Author: | gvzookdriver [ Mon Mar 18, 2013 6:20 pm ] |
Can you use a vitara booster off either a EFI or carbie ?? |
| Author: | KEENSY85 [ Mon Mar 18, 2013 8:31 pm ] |
gvzookdriver wrote: Can you use a vitara booster off either a EFI or carbie ?? X2 |
| Author: | whincup [ Tue Aug 27, 2013 10:40 am ] |
Old thread dig: i have a WT Maruti, will the forester GT master cylinder with the sierra booster be suitable for rear drums? Or does it need other parts added in or no good? If not, whats something that would fit in relatively easy? I have LWB vit front calipers but i dont currently plan to upgrade to rear disc, nor do i need it boosted, i just want the brake pedal to have less travel... |
| Author: | Built4thrashing [ Tue Aug 27, 2013 7:12 pm ] |
Suby Master Clinder is a 1 1/8 bore. It will bolt up to a Sierra booster with minor adjustments to the pushrod. Perfect for disc rear but will work on drum rear also. |
| Author: | got_bar_work [ Wed Aug 28, 2013 9:52 am ] |
Will the gq or suby mc bolt to a 1.6 lwb vit booster |
| Author: | tanshi [ Wed Aug 28, 2013 10:12 am ] |
will bolt up but i think those are the ones with the bolt pattern which is angled 45 degrees. so the MC wouldnt be upright |
