I want to either get a weber/Holley carby or tune the standard carby on vitara. Which will be the best way to go, which will be better for hills, better for power. Not worried about fuel just want to get a bit of power, and the motor will have slight head work. Thanks for any feedback
Joined: Tue Aug 08, 2006 11:30 pm Posts: 5517 Location: Holland Park
Posted: Wed Mar 20, 2013 12:35 am
Standard carb cannot be matched to the weber in flow, therefore it cannot outperform the weber in power. You can certainly improve the weber on angles by modifying the float bowl vents but due to the inherent design of it you will always get fueling issues on large angles.
There should be a few weber threads on here already
Posted: Wed Mar 20, 2013 1:21 pm
Sidedarfts? - draughts? - you know what I mean. Then its only the manifold that's the problem or a 38/38 if gas / outlay isn't a worry. you can get some high comp pistions cheap enough if its the early 1300
Users browsing this forum: No registered users and 183 guests
