It is currently Tue Oct 13, 2026 12:29 am
Post Posted: Wed Mar 20, 2013 7:36 pm
Hi guys,
New to the forum. Just got a question.
I'm looking at fitting the 80mm td lift kit to my 03 jimny. Question is are rear shock relocation brackets needed?
At the moment I have 50mm coil spacers fitted in order to fit the 215/75 dynapros, but am looking to get some proper flex and articulation.
Thanks
Post Posted: Wed Mar 20, 2013 11:50 pm
Without castor corrected radius arms, I'd say yes....you will need relocation brackets for the rear. The lift will cause the diff to rotate back towards the shocks, reducing clearance between the axle tubes and the shock body.
Users browsing this forum: Google [Bot] and 201 guests
