It is currently Fri Sep 25, 2026 3:11 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page 1, 2  Next
Vehicle: 1997 Vitara 2.0
Post Posted: Mon Mar 25, 2013 3:17 pm
Guys, what have i done! I gave the car a wash and in the process thought id spray on some engine de-greaser. I tried to cover some things up with plastic bags. hosed it down cleaned up good...Then when i started the car it ran like absolute S**t! Idled like a mental, wouldn't rev up, sputtering and shaking. I went around the car drying all electrical plugs etc with a hair dryer, then checked the spark plug wells, 2 had water in them! tried soaking up with tissue etc, then took out the plugs, 2 of which had some water on them! Dried them up and the car runs slightly better, idles judders from around 900 to 1100 ish, between 1000-3000 rpm revving is a tad rough, then after that at high revs it sounds alright but then back to a bit rough at lower....I let the engine warm up, then i just took the plugs out and let the hot engine try evaporate any moisture that may be in there.
Any comments? Am i F****D? will it run nice again after a drying out?
I was worried about water all in the engine but i read this comment "Piston rings do an amazing job of sealing the cylinders (thats why they make 150+ psi compression) Since air/gas/fuel hardly ever passes the piston rings, I highly DOUBT that water will pass the piston rings into the crank case."
Colin
Post Posted: Mon Mar 25, 2013 3:24 pm
Let it dry then take it for a drive. It'll be alright
Post Posted: Mon Mar 25, 2013 3:28 pm
Given that you have a J20 vitara, I'd say that it will be a small miracle if you haven't damaged the coil stems. EVERY time I've had moisture near my coil stems, and I've started the car, it has arced a hole through the side of the stem. Exact same symptoms as you describe.
Before starting it again, remove the coil packs, and allow the plug wells to completely dry. Take this opportunity to inspect the stems for arc holes. They will be small ( pin sized ) and may have a grey/white burn mark around them.
Vehicle: SWB Sierra
Post Posted: Mon Mar 25, 2013 3:38 pm
Is this a trait that g16 coil pack motors suffer from too? Or is it a J20 thing?
Post Posted: Mon Mar 25, 2013 3:42 pm
I've got a couple of my G16 motors QUITE wet, and never had an issue. But my vitara is severely hydrophobic. When I wash the engine bay, I always remove the coil packs afterwards and dry thoroughly before starting.
Post Posted: Mon Mar 25, 2013 3:45 pm
I hope so! Fingers crossed!
OK, Ill go check it out... Not 100% sure what im checking but i assume its checking this http://www.flickr.com/photos/44381367@N07/5302067506/lightbox/ for grey/white burn marks?
Hope its obvious to see haha
Colin
Vehicle: SWB Sierra
Post Posted: Mon Mar 25, 2013 4:04 pm
That's good to know.
Post Posted: Mon Mar 25, 2013 4:08 pm
Just checked,all 4 look similar, not marked/burnt...in any way i can tell
Is this anything to worry about on the screw head and spring? only on the one coil...
Post Posted: Mon Mar 25, 2013 5:53 pm
left to dry for hours now. just connected the coils and plugs back in, still runs like S**T at low revs :( took it for a drive, same, quite bad when you try put your foot down.
panic time?
Post Posted: Mon Mar 25, 2013 5:59 pm
It will be one of yor stems.
Check them again and look REAL close.
Post Posted: Mon Mar 25, 2013 6:03 pm
That corrosion won't be helping matters either. Try and clean it up with something
Post Posted: Mon Mar 25, 2013 6:22 pm
Just got them out again, on my table... cant see anything that looks like a small hole in the rubber stem.
I just cleaned the corrosion a tad but that would of been there already i assume
Post Posted: Mon Mar 25, 2013 6:23 pm
there is an easy fix for that. :wink:
Post Posted: Mon Mar 25, 2013 6:42 pm
EDIT
This picture.....
This isnt what you mean is it Fatzook? Is this dirt or something gone wrong like burnt across the gap?
Post Posted: Mon Mar 25, 2013 6:50 pm
swap that coil with another one & see if the miss changes cylinders.
Post Posted: Mon Mar 25, 2013 6:57 pm
I've seen coil packs fail, but its far less common than the stems, and they usually die internally. Never seen a burn mark on a coil yet.
Do what gus said. Mark the coil packs from 1-4 then play musical coil packs.
Post Posted: Mon Mar 25, 2013 7:30 pm
Just did...afraid i dont know what i was listening for? ran rough no matter if i switched them around, or left it with one unplugged. A spark was coming of the middle of each stem...
:( looks like i should just go and buy 4 new stems. eliminate the stems i guess. cheaper than a mechanic!
Post Posted: Mon Mar 25, 2013 7:50 pm
put it all back together & listen to the sound of the motor idling
unplug the coil pack loom from the coil pack for cylinder 1, take note of any difference in idle sound. plug back in & repeat for 2, 3 & 4
it will be the one that DOES not make it idle worse when unplugged.
Post Posted: Mon Mar 25, 2013 8:33 pm
Cheers Gus!
Post Posted: Mon Mar 25, 2013 8:48 pm
i had this after washing mine... it ran rough for 2 full days, and we had temps of around 35 degrees.... it dried out eventually and runs fine now (other than my loose/dirty connector issue over the last few days).
maybe try sneaking them into your oven set to 50*C overnight? =)
Post Posted: Mon Mar 25, 2013 10:45 pm
Spray WD40 or similar through the stems (where the spring is) to remove moisture, wipe the stems down with alcohol and let dry, the corrosion on the spring & screw can be buffed away with a small cup wheel in a rotary tool.
If that white spot is a hole, you'll probably need to replace that coil pack - although you could try gently cleaning it up with a small twist drill (to remove the charred plastic) and filling it with RTV sealant - it might work if there is no internal fault. I did have success with this on a Mitsubishi coil pack, but the hole was in a different place and because of it's location (through the barb where the stem fits) it was clear that there was no internal short.
Post Posted: Mon Mar 25, 2013 11:04 pm
This gives me a bit of hope that I just MIGHT get away with buying stuff! As I did what Gus said and it really didnt make a difference, I took one out, ran a little worse than with 4 in. then change over to another plug out, same for each one... hopefully it just might have moisture in there still. If its not right tomorrow afternoon ill get some new coil boots/stems.
Cheers mate, give this a go and leave it all over night!
At least I have a cleaner engine hahaha, degreaser worked a treat. Thanks all you Auszookers! world of knowledge on this place!
Post Posted: Tue Mar 26, 2013 1:34 am
just a note on holes with these things. My old hyundai excel had a similar problem (turned out to be a hole in the coil stem too). the hole was so small you literally could not see it. Found it by accident when I was disconnecting the leads and saw the arc fly out the side, looked like it was just coming out the plastic. Turned the engine off... no evidence of a hole. Was absolutely bizzare. I wrapped eleccy tape around the suspect area to confirm fault... sure enough, problem went away. So maybe get creative with some tape to isolate the problem?
I obviously have no experience on the vitty, but thought that little anecdote may help.
MY BUILD THREAD HERE!!!!!
Post Posted: Tue Mar 26, 2013 11:35 am
Thanks for that! Ill go get the tape out and see how that goes Im sure the stems were arcing around mid way!
Post Posted: Tue Mar 26, 2013 7:56 pm
Put plenty of layers and wrap tightly, otherwise it will still want to bust through.
This is not permanent fix btw.
Vehicle: 92 tintop sierra
Post Posted: Tue Mar 26, 2013 8:07 pm
Tape works wonders.
Also sometimes if you look down the spark plug hole of the rubber boot you can see the arc track mark if they are arcing down the tube.
Post Posted: Tue Mar 26, 2013 8:12 pm
the probes are a really tight fit and being ribbed for extra pleasure it's hard to get a good tight wrap on it without adding too much girth so it doesn't fit in the hole. :D
Post Posted: Tue Mar 26, 2013 8:38 pm
LOL
bloody crow eaters. Not gettin any at home ey Gus?
Post Posted: Tue Mar 26, 2013 8:42 pm
Scales wrote:
LOL
:lol: just stuck at work being busy & trying to entertain myself.... ask shakes if he's still got those pics :wink:
Post Posted: Tue Mar 26, 2013 8:57 pm
HAHA nice description Gus!
IT was rough this morning and midday, so i just went out and Iv been fiddling around with it trying to detect which cylinder is buggered and for some reason its decided to play nice... not sure how its 'fixed' its self but seems to be ok?
Users browsing this forum: Google [Bot] and 487 guests
