It is currently Sun Nov 01, 2026 2:13 am
Post Posted: Sat Apr 06, 2013 2:43 pm
Hi all
Hope someone can help. Recently replaced the rocker cover gasket on my 89 1.6 Vitara hoping to fix an oil leak that finds its way down the back of the engine and over the bell housing.
As mentioned, chucked in a new rocker cover gasket and rubber stud seal things, wiped the oil off my hands and stepped back. Now that'll stop those pesky leaks I think to myself.
Damn thing still leaks, seems worse if thats possible.
Only other thing I can think of is the distributor thats mounted at the back of the engine. Is it common for oil to leak here, is it a hard fix. One guy I spoke to said "O"Ring, another said Seal. Not sure whats in there but just fishing for tips.
Ric
Post Posted: Sat Apr 06, 2013 3:07 pm
There's an o-ring where the distributor sits in the housing and a seal (gasket/sealant?) where the housing bolts to the back of the head. Both are common places for leaks
Post Posted: Sat Apr 06, 2013 3:19 pm
Hmmm, Just went out to chuck some more oil in the old girl. Dip stick showed nothing, must be a bit low. Now the weird thing is I topped up the oil, stuck my head around the back of the engine and noticed oil dripping from the fuel pump. Looks like its coming out between where the upper and lower body fit together.
Really strange that it started dripping out after I topped up the oil, didn't fire up the engine and it has been sitting for a few hours.
Post Posted: Sat Apr 06, 2013 3:20 pm
There's a gasket where the fuel pump mates onto the head too. Can you get a pic up?
Post Posted: Sat Apr 06, 2013 7:00 pm
Yep, I see the gasket between the pump and the cylinder head. Will have a closer look in the daylight, that gasket is an easy fix but I suspect the fuel pump is rooted.
Vehicle: suzuki vitara
Post Posted: Sat Apr 06, 2013 7:04 pm
it will be the fuelpump itself, not the gasket.
only thing you can do is replace it as it can't be fixed.
Post Posted: Sun Apr 07, 2013 9:57 am
Yep. I reckon its fuel pump replacement time.
Hmmm, I wonder if ethanol is my enemy here...... Or probably old age I suppose, its been doing a lot of pumping in its lifetime
Vehicle: 93 Vitara -itty bitty lift
Post Posted: Sun Apr 07, 2013 4:56 pm
ethanol is hard on the rubber and alloy components in you fuel system, but so is old age
Post Posted: Sun Apr 07, 2013 5:30 pm
Ethanol is the enemy of all old fuel systems!
Post Posted: Tue Apr 09, 2013 12:40 pm
Just to follow up in case anyone has this problem in the future.
Replaced the fuel pump and all is good.
Looks like the fuel pump has a relief hole, similar to whats in a water pump. this is where the oil was leaking from and not from between the top housing and casting as I first thought.
Cheers all and thanks for your input
Users browsing this forum: No registered users and 453 guests
