It is currently Wed Nov 04, 2026 2:52 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2  Next
Vehicle: Jimny 2009 vvt JIL
Post Posted: Tue Mar 26, 2013 11:37 pm
Hi guys.
I have an idiotic plan i want to atach some sort of lever to each sides cable of my hand barnk with two seperate levers for left and right.
So i want to idividual be able to brake my left rear tire aswell as to individual brake my right hand rear tire without to compromize my current hamdbrake in place.
Do you guys think this can work?
Then i can applly the bracking to the wheel that is spinning so that torque can be applied to the weel that is standing still?
I know this sounds crazy?
But is it crazy enough to work?
Thank you
Happy Zooking :)
Post Posted: Tue Mar 26, 2013 11:40 pm
There is a fella that done this to his vitara and it worked pretty well ill go find his build thread now :D
Post Posted: Tue Mar 26, 2013 11:45 pm
Will you please share it with me :) cant wait to go on a grail with some axle twisters after its done in JIL
Post Posted: Tue Mar 26, 2013 11:47 pm
The system you're referring to is known as fiddle brakes or cutting brakes and yes, it works well providing the brake is strong enough. With small tyres you'd get away with using the stock hand brake system on most cars. You can buy hydraulic cutting brake kits for 4WDs.
Practically every tractor has them, pretty useful on older/lower spec'd ones that don't have lockers.
Post Posted: Tue Mar 26, 2013 11:48 pm
Not to many details on it but there are some pics on this page viewtopic.php?f=4&t=20425&start=300
Post Posted: Wed Mar 27, 2013 6:18 am
There is a far easier system that will take the strain off the driver having to think etc.........called a real diff lock.
Post Posted: Wed Mar 27, 2013 7:18 am
hahah it will put some strain on my financial capacity:) and with the 3 inch lift project amd the lovely lady i am spending time with , (a woman not another jimny ) hahah :) so i was looking just for something like this :) just to play around and make things more interesting and experimenting :)
Post Posted: Wed Mar 27, 2013 7:40 am
If you were to do it well, you'd use a hydraulic cutting brake. But by the time you sort that out you could have spent the money on an auto locker.. Or on your way to an air locker.
Post Posted: Wed Mar 27, 2013 7:53 pm
I'll have cutting brakes in my Jim before too long ;) buttons are already in yess!!
Post Posted: Wed Mar 27, 2013 8:22 pm
I think this is a great option for extra traction and is something I've often considered trying. VW off road buggies have used this concept for a long time, both cable and hydraulic.
You would need to be a hands on sort of driver though. It falls into a similar argument as the 2wd low mod.
Post Posted: Wed Mar 27, 2013 8:27 pm
Haha, I wouldn't say that.
Just, cheap.
Post Posted: Wed Mar 27, 2013 8:44 pm
haha well it give the co -driver something to do :) wile i keep my hands on the steering :)
Post Posted: Wed Mar 27, 2013 8:48 pm
Just, cheap.
Wouldn't say what?
Post Posted: Wed Mar 27, 2013 8:52 pm
Similar argument to twin stick.
Post Posted: Wed Mar 27, 2013 9:06 pm
Similar in that some people totally see the purpose and some totally don't and the discussion will just go back and forth much like we are already ;)
Post Posted: Wed Mar 27, 2013 9:11 pm
altugh an auto diff lock would be a good option if u can do it yourself, but the project seems awesome and fun to do.
I dont know how you see it and how everyone sees it either, but imo this falls into a different category of diff locks.... as this system would be seem as a "recovery" system, where he get stuck, apply the hand brake and off he goes... instead of a "preventive" system of a diff locker, where he would be able to drive it from the beginning.....(it would be pretty hard to apply the brakes on and off manually and accordingly of the terrain as you re driving it in real time)
so end result both different driving styles and approaches to an obstacle
I donno, I might be wrong but that was my impression :)
Post Posted: Wed Mar 27, 2013 9:17 pm
First attempt you flex up and loose traction on the drooping rear wheel. Second attempt you know to pull that lever just as you start to Lose traction.
As you say Bert it would be fun to give it a go.
Post Posted: Wed Mar 27, 2013 9:23 pm
:lol:
Post Posted: Wed Mar 27, 2013 9:30 pm
Then you need a bit more speed so you have to change gears and then you have to steer hard into a rut which requires both hands on the wheel and you soon run out of hands :wink:
Post Posted: Wed Mar 27, 2013 9:45 pm
Lockers:1
if youre insistant. Look at the CNC brand cutting brake levers a better version of your idea.
Post Posted: Wed Mar 27, 2013 9:48 pm
Change gears wtf, steer into the rut ??? Need more speed?
Auto locker for you me thinks
Post Posted: Wed Mar 27, 2013 9:54 pm
I believe he was making a realistic scenario.
Not just flexing up.
Post Posted: Wed Mar 27, 2013 10:50 pm
I believe that if he would be into hardcore stuff he would already have a locker or be talking about one instead of this
Post Posted: Thu Mar 28, 2013 6:43 am
Care to elaborate?
The topic says "difflock diy"...
Post Posted: Thu Mar 28, 2013 6:48 am
I think the only relevant use for fiddle brakes is for competition, either trials, where they can improve turning performance, or in classes where diff locks are forbidden.
They do work, but they require a lot of driver skill to be effective. I vote not worth the effort. Get a diff lock. Much more effective and no special skills required.
Post Posted: Thu Mar 28, 2013 7:12 am
SierraDan wrote:
Care to elaborate?
Glad someone else read it that way too.
Post Posted: Thu Mar 28, 2013 7:42 am
X2
Might end up a whole heap cheaper too.
Post Posted: Thu Mar 28, 2013 9:32 am
X2
+7
Seems electronic traction control doesnt work with an ECU and a bunch of sensors doing the same thing to all 4 wheels, you can do it to 2 wheels only and will need outside assistance to work out which wheel and then try and apply it at the right time whilst working all the other controls
I vote for just going out and learning how to drive what youve got already
Vehicle: 85 ' Drover
Post Posted: Thu Mar 28, 2013 9:47 am
Meh ignore the pesimists. Give it a go eh.
Even if it costs you a bit, the academic excercise in getting it to work would be pretty enjoyable i would think.
I like the look of that dual level dual piston arrangement above. Would you ever want to lock both wheels at same time?
As what about if you got 2 master cylindres, mounted them facing each other, and used 1 lever to control both of them? push it one way and it locks the left wheel, push it the other way and it locks the other way. might have to think up somethign tricky so that you dont pull them too far in the wrong direction (ie pulling the piston out of the bore)
If you are running rear disc brakes, you could attach another caliper to each rear disc purely for this contraption. they do this kind of thing all the time on the drift cars for their hydraulic handbrakes, so they are seperate from the normal brakes.
Post Posted: Thu Mar 28, 2013 9:57 am
Give it a go like a Z9?
The levers can be setup for forward and back, and are often done so.
Users browsing this forum: No registered users and 93 guests
