It is currently Tue Nov 03, 2026 8:34 am
Vehicle: Jimny 2009 vvt JIL
Post Posted: Wed Apr 03, 2013 8:47 am
Hi guys,
Can someone post to me some pics of a new caster correction radius arms nextb to the standard radius arms for a 3 inch lift like from jimnybits,
I measured the distace of the three mounting point at my current setup, and then i jacked up the car 75 mm. (just the chassis)
So know i got both set of measurements ,
I did some drawings on cad , but the centre of the new holes in the new radius arms are not that different from the standard arms.
Any help would be appreciated thank you.
Post Posted: Wed Apr 03, 2013 9:09 am
Here is my drawing, the new radius arm is on front, please ignore the general design just look at the angle to move the axle in the right place.Image
Post Posted: Wed Apr 03, 2013 9:18 am
That looks bout right. How many degrees did you roll the mounts?
Vehicle: 2008 Jimny Standard As :-)
Post Posted: Wed Apr 03, 2013 10:29 am
Here dude,
hope this helps
Post Posted: Wed Apr 03, 2013 10:31 am
there are some pics on ppls built treads, dont remember who so wait till someone reads in here.
also if I not wrong the jimnybits arms and also the ORA ones move the axle forward a bit too to return it to his original position but with the lift.... something you can consider too while you are there making some drawings ;)
Post Posted: Wed Apr 03, 2013 1:37 pm
Yeah I have jimny bits arms in my car and they push the diff forward as well as fix the angle.
Post Posted: Wed Apr 03, 2013 3:14 pm
hi guys , thanx for the comments, that is about 2.7 degrees anti clockwise.
I willtake the radius arm off the car to make a more accurate drawing .
I also need to measure the back so that is still to come....
Thanx :)
Users browsing this forum: No registered users and 112 guests
