http://auszookers.com/forum/
Jimnybits 3" diesel lhd vs petrol rhd?
http://auszookers.com/forum/viewtopic.php?f=5&t=40053
Author:  macguyverjimny [ Fri Apr 05, 2013 1:18 am ]
Post subject:  Jimnybits 3" diesel lhd vs petrol rhd?
Hi Guys ,
Does anyone know what is the difference in the models in terms of the spring supplied by jimny bits?
There is a LHD diesel, and then the RHD petrol
Thank you
Author:  zooky08 [ Fri Apr 05, 2013 12:23 pm ]
Post subject:  Re: Jimnybits 3" diesel lhd vs petrol rhd?
The diesel ones will have a heavier spring rate.
Author:  macguyverjimny [ Fri Apr 05, 2013 2:43 pm ]
Are they more stiff?
can I put them on a petrol model?
I have a petrol but ordered the diesel springs , will it be a train smash?
Author:  atari4x4 [ Fri Apr 05, 2013 2:46 pm ]
Why did you do that? :?
Author:  macguyverjimny [ Fri Apr 05, 2013 2:54 pm ]
ahh crap. the others was out of stock.
well so im kinda screwed right now?
Author:  BertZook [ Fri Apr 05, 2013 3:29 pm ]
think ull be ok as long as u have a bullbar.... correct me if Im wrong ppl with the lift ?
Author:  macguyverjimny [ Fri Apr 05, 2013 3:44 pm ]
Got a bar and a a winch.
Really hope this is fixable.....
Author:  Fatzook [ Fri Apr 05, 2013 5:07 pm ]
Why don't you just ask jimny bits what the difference in rate is?
Author:  macguyverjimny [ Fri Apr 05, 2013 5:25 pm ]
i did sent russ a ticket, waiting for his reply,
The springs is already dispatched i think so its hard to exchange it, and i think the rhd petrol is out of stock,
Thanx for your help :)
Author:  ajsr [ Fri Apr 05, 2013 5:55 pm ]
fairly obviously if they were the same there would not have been a petrol diesel option
Author:  macguyverjimny [ Fri Apr 05, 2013 7:02 pm ]
the disel springs are longer in the front to cope with the extra weight,
thanx .
gor a reply from russ.
Author:  kristov [ Fri Apr 05, 2013 7:17 pm ]
yeh ive got diesel springs and it sits level with bar
Author:  macguyverjimny [ Fri Apr 05, 2013 8:17 pm ]
Thank you
Cant wait.
Author:  Gough [ Mon Apr 08, 2013 7:24 am ]
The springs are stiffer, I have the 50mm diesel springs in my petrol, was bumpy but with a bull bar a lot better and if you put in a winch it will drive pretty smooth, if you don't put a bull bar on don't get the diesel springs it will be bumpy
Author:  macguyverjimny [ Sat Apr 13, 2013 12:58 am ]
Is this correct? There is only 3 extended break hoses from jimny bits?
Thank you,
Got coils, will soon order shocks, and then after that pay for caster correction.
Very exited. :)
Author:  kristov [ Sat Apr 13, 2013 9:13 am ]
yeh thats normal theres 1 on back and 2 on front
Author:  macguyverjimny [ Sun Apr 14, 2013 12:14 am ]
thank you.
i want to get the rest o the stuff and get it installed, cant wait anymore :)
Author:  BertZook [ Fri May 24, 2013 5:51 pm ]
I dint want to start a whole new tread.
I recently check the website and now they are selling a new "all in 1" package for the 3" lift, witch is cool, I havent compare the price to doing it individually tho
but the thing it called my attention is that now the kit comes wih rear castor corrected radius arms too.
also with the 25mm prop spacer for the fornt, as the new arms move the axle bit forward witch is cool, but they dnt seem to have for the rear?. so why build the new arms if they dnt do the same as the front in put the wheels on the "right" place
also they ssay the the new rear arms are castor corrected too, so the shock relocation brackets are no longer needed as the axle is rotated back to stock. cool, but now the shock is on the original angle on the bushes, wonder if they would still pop out
either way just wanted to mention that.
also now they have a new option for the coils in a LHD petrol, together with the old RHD petrol and LHD diesel.
nice to see they think bout us :mrgreen:
Author:  Bugsta [ Wed Jun 12, 2013 8:40 am ]
macguyverjimny wrote:
Hi Guys ,
Thank you
Please let us know how you find it. With regards to stiffness, ride height etc.
I was considering this option but found a local alternative that I am happy with for the moment.
Could you give us some measurements, perhaps from chassis to radius arm brackets (F&R of each diff), for comparison.
