http://auszookers.com/forum/
fused battery terminal or fusible link?
http://auszookers.com/forum/viewtopic.php?f=5&t=40070
Author:  hooki [ Fri Apr 05, 2013 8:04 pm ]
Post subject:  fused battery terminal or fusible link?
hi AZ,
Does anyone see any problems with running one of these fused battery terminals with an 100Amp ANL fuse instead of a fusible link on my sierra? My plane is to run a suitable sized wire from the 110amp falcon alternator straight into this terminal on the battery. Then I'll run the factory yellow/white wire into one of the auxiliary fusses in the terminal aswell.
I was thinking this would make things a little neater with the wiring but if you guys don't think it's worth it I could just get the an auto spraky to make me a new fusible link to suit the 110A alternator.
http://www.ebay.com.au/itm/281075545296 ... 1423.l2649
thanks :D
Author:  royce [ Fri Apr 05, 2013 8:13 pm ]
Post subject:  Re: fused battery terminal or fusible link?
I would do it, not that terminal though cause there is nowhere for the starter cable to go
Author:  Mike57 [ Fri Apr 05, 2013 8:17 pm ]
Looks more like a terminal for the second battery. I am not sure what the starter current is for a Suzuki but quite possibly up near 100 amps. I agree with Royce. I like the look of the terminal set up but no where to connect a winch or starter cable, that is why I think it is not meant for the main battery.
Author:  hooki [ Fri Apr 05, 2013 8:24 pm ]
ahh you guys are right, I completely forgot about the starter wire :oops: haha. Does anyone know of any fused terminals that would work? I can't seem to find any others online. I suppose if I can't find a suitable terminal I could just put a 100amp fuse in a fuse holder?
thanks guys.
Author:  boostedbrick [ Fri Apr 05, 2013 8:41 pm ]
Can you run a circuit breaker? There are some high amp multi outlet breakers out there, either auto resetting or manual. Remote mount it with some 0 gauge.
Author:  royce [ Sat Apr 06, 2013 7:01 am ]
I know a site has what you want but its down right now
have a look around a wreckers at some late model stuff, I reckon you'll find something to suit you
Author:  Ausuki [ Sat Apr 06, 2013 7:54 am ]
it claims you can run a starter off the 8mm post
"CAL2 Fuse Technology
Allows the load of a starter motor or winch to operate without blowing the fuse, but is still sensitive enough to blow in the case of a direct short. 150A continuous/800A peak fuse. "
for $40 id give it a try
Author:  hooki [ Sun Apr 07, 2013 4:43 pm ]
cheers I might have a look at the wreckers for something suitable :)
