It is currently Fri Oct 16, 2026 6:34 pm
Post Posted: Sun Apr 14, 2013 8:05 pm
Does anyone have an AW3 with transfer on it they could run a tape measure over and give me an overall length on?
Thinking about a engine/transmission change and about dual transfers...
Cheers,
Chris.
Post Posted: Sun Apr 14, 2013 8:11 pm
What is an AW3?
Post Posted: Sun Apr 14, 2013 8:17 pm
Cheers,
Chris.
Three speed auto? If so that is made by GM not Aisin Warner.
Post Posted: Sun Apr 14, 2013 10:44 pm
Three speed auto. Yes. Vitara Auto.
Sorry about the lack of clarity.
Are the three and four speeds the same overall length
Post Posted: Sun Apr 14, 2013 10:49 pm
Should be pretty close to the AW4. Without giving you any actual information, the difference between the 3 and 4speeds inc transfer would not be enough discount one over the other as a candidate for trans and dual transfer swap. Just pick the one that works best for your needs ( gear/ ratio spread ) and have at it.
Post Posted: Sun Apr 14, 2013 10:52 pm
Three speed auto is the same length as the five speed manual four speed auto is a fair bit longer then the other two
I'm not sure on actual lengths though
Post Posted: Sun Apr 14, 2013 10:54 pm
I've got a 4sp down stairs, but I couldn't be bothered going to get a measurement now.
Post Posted: Mon Apr 15, 2013 5:23 am
910mm from bellhousing to output
Vehicle: zook buggy
Post Posted: Mon Apr 15, 2013 10:03 pm
the tranny pan on the 3spd is alot wider to, so you need to run a small dia shaft
Post Posted: Mon Apr 15, 2013 10:37 pm
I have a 3 speed auto sitting in the garage. Ill measure it up for you tomorrow. They are definitely shorter than a 4 speed by about 130mm iirc
Post Posted: Tue Apr 16, 2013 6:13 am
Save yourself the hassle and just scroll up a couple posts :roll:
Post Posted: Tue Apr 16, 2013 6:58 am
My bad. for some reason I thought that was for the 4speed.
Post Posted: Sat Apr 20, 2013 2:14 pm
Thanks for the info, So 910mm including transfer for the 3 speed, and a bit longer?? for the 4 spd.
I will measure and ponder, which transfers have the 1:1 high ratio? and are they interchangable between 3 and 4 speed?
Post Posted: Sat Apr 20, 2013 3:07 pm
ALL vitara transfers have 1:1 high.
Post Posted: Wed May 01, 2013 7:41 pm
Any chance of that 4 Speed OAL?
Post Posted: Wed May 01, 2013 8:46 pm
G16B AW4 and transfer I get 915mm.
J20 AW4 and transfer I get 945mm. (bellhousing is 30mm longer)
Not sure where these +130mm measurements are coming from ^^^^^^^
Post Posted: Wed May 01, 2013 9:00 pm
I was sure I'd read 130mm somewhere.
Going by the trail tough installation instructions for their auto conversion kit the measurement U-joint Center to U-joint center of the jackshaft is as follows
3 speed - 7 1/8"
4 speed - 3 3/4"
so that means the output of the 4 speed is 3.375" further back which makes it 85.725mm longer than the trimatic
Post Posted: Wed May 01, 2013 9:06 pm
3 speed - 7 1/8"
4 speed - 3 3/4"
That may be the case after you take the extension housing off the back, but overall length with the transfer doesn't seem to be much different. And since the OP is after a length WITH the transfer, your point is moot.
Users browsing this forum: No registered users and 317 guests
