It is currently Fri Oct 30, 2026 5:53 pm
Vehicle: LWB Sierra & XL7
Post Posted: Tue Apr 23, 2013 6:04 pm
Well I got to finally drive my Vitara for the first time in about 6 months and well.... A couple of things..
Cold start isn't very easy - I have to keep the key turned and hold the accelerator down a little for it to fire up
Down low there's no go - anything below 2500rpm is a struggle even with the pedal mashed to the floor then it's as if it go's oh hang on I can do this, and the power delivery is a little all over the place.
The ignition timing is spot on 10degree BTDC when cold. I didn't have a chance to check it when hot.
Would the TPS be affecting it. It was removed and not set back in it's original location.
'92 Vitara & Camper trailer
Post Posted: Tue Apr 23, 2013 7:04 pm
How smooth does it idle? On some vits the TPS has an idle switch which should make contact at idle to tell the ECU. This should be setup
Post Posted: Tue Apr 23, 2013 7:30 pm
cam timing correct? 100% confident you did the valve tune up correctly?
Post Posted: Tue Apr 23, 2013 8:54 pm
It idles very nicely and revs freely, just when it's under load it kinda struggles.
This is the link I got my info from and I made a little video which is in the last post of what I did. http://auszookers.com/forum/viewtopic.p ... ilit=video
No rattles or clunking noises so I'm certain it's right.
Post Posted: Thu Apr 25, 2013 1:22 pm
have u changed ur fuel filter recently? time for a new one maybe.
pretty sure they use a wax pallet thing for the choke, maybe this isnt operating correctly? not sure if they can fail or not.
Users browsing this forum: No registered users and 265 guests
