[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
scottysj80
Joined: Mon Jan 12, 2009 10:30 pm Posts: 677 Location: south west rocks, mi
 Posted: Tue May 07, 2013 9:58 am |
Hay guys, just won't to no if all the 5 speed gear boxes out of the efi 1.6L vitara are the same? I've got a 94 model lwb vit that I'm changeling the gear box in and I have got one out of a 95 model swb to go in it but both boxes have different stamps on them ? Like one has M1 and the other has m5 stamped on the sides? Also the newer box has 4 different plugs that the wires plug into and my old one only has 2 plugs that the wires were plugged into, how ever there are the plugs built into my original wiring harness for the plugs on the new box to be able to all plug in but I'm wondering what the 2 extra plugs are for?
Cheers scott
scottysj80
 Posted: Wed May 08, 2013 3:32 pm |
So dose anyone no if all the 5 speed Vitara gear boxs are the same? Are all the ratios the same etc just want to no befor I go to all the effort of putting it in that it will be the same as the old one?
Haven't had any luck with the serch function on this sight as it seems to only come up with crap lol
Any help would be great guys
Cheers Scott
scottysj80
 Posted: Thu May 09, 2013 8:20 pm |
Rhinoman
Joined: Mon May 16, 2011 7:03 pm Posts: 686 Location: Brinkworth, England
 Posted: Thu May 09, 2013 9:12 pm |
There were some differences over the years. Put it into fifth, turn the input shaft and count how many times the output shaft turns, also check the number of splines on the output.
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Fri May 10, 2013 12:08 pm |
There is at least 2 different ratios for 5th but i dont know what car has wat
scottysj80
 Posted: Fri May 10, 2013 12:21 pm |
Do you no if there is much difference in the two 5th gear ratios ?
Rhinoman
 Posted: Fri May 10, 2013 5:08 pm |
Over here the 16V has a taller ratio than the 8V but I've no idea what may have been fitted on the JDM models. 8V = 0.85 16V = 0.8
Its not a big difference but if you have an 8V running taller tyres then you will notice it.
[ 7 posts ] |
Users browsing this forum: No registered users and 300 guests
