Vehicle: 1981 suzuki 1.3l corolla
Posted: Fri Apr 26, 2013 5:41 pm
I brought a Suzuki 1995 leafy a while back with a vitara g16b conversion in it and I was told that it had a 1.3l head fOr more compression and it had been rebuilt I have had an over running problem with it ever since I got it it overruns when I turn off the car and sometimes running backwards for a second this worries me I tried different carbys spark plug leads distributor cap and I've played with the timing a heap still does it but only when the engine is hot . The plug that plugs into the carby is that a fuel shut off solinoid ?? What does it do . Need help thanks mickĀ ow and I did a compression test and it shows about 200 psi per piston
Posted: Sun Apr 28, 2013 7:57 pm
Whoever has done the conversion I think they have completely disconnected the solenoid because it works when I pull it off And test it but doesn't work with the car ignition might have to do a few other things but of trial and error I supose I adjusted the valves today and that didn't help
Users browsing this forum: Google [Bot] and 137 guests
