http://auszookers.com/forum/
removing jimny gearbox
http://auszookers.com/forum/viewtopic.php?f=5&t=40566
Author:  zooky08 [ Sat Apr 27, 2013 2:11 pm ]
Post subject:  removing jimny gearbox
Ive tried searching but cant find any info how to remove a jimny gearbox.
Ive got every thing undone, but i cant seem to get the box far enough back past the cross member to Alow the bellhousing to clear the clutch.
Does any one know the best way to remove a non vvt jimny gearbox .
Author:  31zook [ Sat Apr 27, 2013 3:16 pm ]
Post subject:  Re: removing jimny gearbox
Normally the pull back and twist over eitherway...
Not sure that will work for you, but you might have to rock the engine forwards and backwards to get it also.
Author:  PORL [ Sat Apr 27, 2013 5:35 pm ]
Unbolt engine mounts and lower the motor. It's a bitch
Author:  Scales [ Sat Apr 27, 2013 5:54 pm ]
yeah i've heard some people need to pull the engine forward a touch with straps or something too!
Let us know how you get on, I may need to do my nonvvt soon too!
maybe this will help
http://www.bigjimny.com/images/document ... Clutch.pdf
remember if you have enough access to the breather on the gearbox, chuck a hose on it! this will probably be the only chance you get to put a decent breather on there.
Author:  BAZZOOK [ Sun Apr 28, 2013 5:23 am ]
push the gearbox to the rear and remove the clutch. gearbox will then just drop out. refitting is the reverse. I used a mirror and torch to align the splines with the spigot bearing
Author:  zooky08 [ Sun Apr 28, 2013 8:46 am ]
Thanks guys, ended up undoing engine mounts and lifting engine.
