http://auszookers.com/forum/
ARB CKMA12 who's got one?
http://auszookers.com/forum/viewtopic.php?f=5&t=40590
Author:  PORL [ Sun Apr 28, 2013 8:52 pm ]
Post subject:  ARB CKMA12 who's got one?
http://www.arb.com.au/products/arb-air-compressors/
The high output on board CKMA12
Are you happy with it?
What's your experience?
I will be using it for pumping tyres and lockers later on
Author:  atari4x4 [ Sun Apr 28, 2013 8:56 pm ]
Post subject:  Re: ARB CKMA12 who's got one?
yess!!
Author:  jono165 [ Sun Apr 28, 2013 9:18 pm ]
Got one, pumps up my 31's fast enough, the included loom was plenty long enough, compact size is great. Ive had plenty of mud and stuff on it and used the pressure hose to clean it off and its never missed a beat.
It might not be as quick as some others out there but its reliable and i think thats what matters. If i upgraded mine it would only be for the twin piston one. The good thing about the ARB compressors is they actually publish the CFM at a given psi. others just say 150lpm but you can only assume thats at free air delivery
Author:  PORL [ Sun Apr 28, 2013 9:29 pm ]
I'm only pumping up 235/75r15 mounting it behind the passengers seat. How does it go heat wise?
Author:  jono165 [ Sun Apr 28, 2013 9:33 pm ]
It gets pretty warm by the time you have pumped up all the tires, but theres plenty of people who have theirs mounted under the seats etc so shouldn't be a problem
Author:  PORL [ Sun Apr 28, 2013 9:35 pm ]
Warm enough to melt carpet?
Author:  jono165 [ Sun Apr 28, 2013 9:42 pm ]
It gets hot to the touch, whether or not it would melt carpet i dont know. I'm sure someone with one mounted internally will pipe up and let you know. You could always shield the carpet with a bit of sheet metal bolted through the base with it.
Author:  PORL [ Sun Apr 28, 2013 9:43 pm ]
This is true, thanks heaps
Author:  Scales [ Sun Apr 28, 2013 9:53 pm ]
I got one, love it.
Gets fricken hot, but has a cut-out to prevent damage. Mines bolted to underside my false floor, right next to my seat and some marine carpet (look at my build for pics) never had a drama.
The cut-out has only cut in once when I was up to the 7th tyre I was inflating at the time.
Author:  PORL [ Tue Apr 30, 2013 2:07 pm ]
Best place to buy one? Cheapest.
Author:  Scales [ Tue Apr 30, 2013 2:34 pm ]
ARB only item mate, so... ARB? dont think other stores stock their gear.
or 2nd hand.
You should be able to talk them down in price a bit, I think I got the compressor and air-up kit for 300-320ish when I got mine.
Author:  jimmy91 [ Tue Apr 30, 2013 6:53 pm ]
You could save like 30 by going on eBay but then you have to wait! I love mine it's in it's 2nd car. I pump my zook tires up then friends 35's and it doesn't cut out. Takes a bit with the 35's though
Author:  atari4x4 [ Tue Apr 30, 2013 7:34 pm ]
Scales wrote:
I got one, love it.
interesting that you had the thermal cut out kick in, mine is mounted in my engine bay, by the brake booster & the other weekend i pumped up 6x 31's (4 on the zook + 2 on the trailer) 4x 35's on a GQ & 4x 235's on a Jimny & didn't get hot enough to trip the cut out, wonder if the lack of airflow caused yours to trip thermal cut out?
thought the heat soak from the engine bay would have effected it more, but maybe not. :?
Author:  jimmy91 [ Tue Apr 30, 2013 7:44 pm ]
Maybe check the air filter?
Author:  atari4x4 [ Tue Apr 30, 2013 7:50 pm ]
why, have you seen the sintered brass filter on a ARB compressor?
Author:  PORL [ Tue Apr 30, 2013 8:29 pm ]
Maybe it was a hotter day, less or more humidity in the air, different hose set up, nozzle set up, ect
Author:  Scales [ Tue Apr 30, 2013 9:17 pm ]
Hot, Humid, typical nth qld day, was pumping up massive tyres on my brothers car and mine on pretty much constant duty cycle. ARB air hose kit, and you've seen where I have it mounted.... and if you havent
I only use the compressor with the seat forward, I need to anyway to get the hose out from under the seat, so airflow is okay, no worse than a hot engine bay.
Do these things need a bit of machine oil every now and then or anything?
