| Central Australian fuel saver device. http://auszookers.com/forum/viewtopic.php?f=5&t=40625 |
| Author: | luke3411 [ Tue Apr 30, 2013 4:01 pm ] |
| Post subject: | Central Australian fuel saver device. |
So all of our cars in the car park have been raided recently so I thought fuck it, I dont mind doing things to my car and it might just appeal to a few other people wherever you are that are suffering the same problem with Petrol sniffers. If they get through this I'll be pissed and will have to resort to more extreme measures involving a box of match's. Got the lock yesterday and after some thought and some preperation it was to easy to do. Measure, drill, lick of killrust and bolt it on with a backing plate and it was done. So who else is driving through central Australia on the way to the Auszookers meetup and is worried about there fuel getting robbed for someones jollys? |
| Author: | Matthew [ Tue Apr 30, 2013 4:21 pm ] |
| Post subject: | Re: Central Australian fuel saver device. |
Not quite so easy on a Sierra. |
| Author: | luke3411 [ Tue Apr 30, 2013 4:26 pm ] |
Matthew wrote: Not quite so easy on a Sierra. Everything is possible with a few hours and some tools. |
| Author: | ball [ Tue Apr 30, 2013 4:39 pm ] |
the local Neanderthals will chew that off pretty quick |
| Author: | luke3411 [ Tue Apr 30, 2013 4:44 pm ] |
ball wrote: the local Neanderthals will chew that off pretty quick Hopefully not. Thats why I have the backing plate to stop it all pulling through. There is a bunch of other cars in the car park so hopefully they see mine and give up to go to the next car. |
| Author: | ball [ Tue Apr 30, 2013 5:09 pm ] |
luke3411 wrote: ball wrote: the local Neanderthals will chew that off pretty quick Hopefully not. Thats why I have the backing plate to stop it all pulling through. There is a bunch of other cars in the car park so hopefully they see mine and give up to go to the next car. you get points for being an optimist |
| Author: | atari4x4 [ Tue Apr 30, 2013 5:18 pm ] |
FYI vitara's have an anti siphon ball thingo in the neck of the tank... i tried draining the tank on the SWB by siphoning it & failed to get a hose any deeper than the filler neck. ended up running the fuel pump to drain 50l out of the sucker. |
| Author: | JrZook [ Tue Apr 30, 2013 5:47 pm ] |
They will probs just stab your tank instead now |
| Author: | just_cruizin [ Tue Apr 30, 2013 6:01 pm ] |
You've locked it therefore the must be something worth stealing, that's what sierras are all about, leave em open and people just walk right past |
| Author: | ball [ Tue Apr 30, 2013 7:22 pm ] |
just_cruizin wrote: leave em open and people just walk right past not the ones here If it's not nailed down its gone, if it's nailed down its gone after a slight delay |
| Author: | mnemonix [ Tue Apr 30, 2013 11:28 pm ] |
If it's not nailed down it's probably because the bastards stole your nails. |
| Author: | ZukinLao [ Wed May 01, 2013 10:20 am ] |
JrZook wrote: They will probs just stab your tank instead now Get one of the TSOR fuel tank guards... |
| Author: | luke3411 [ Wed May 01, 2013 11:03 am ] |
Hopefully they dont get stab the tank. Wouldn't be suprised. I really hope that it is a deterrent and they just move on to the next car. |
| Author: | ball [ Wed May 01, 2013 12:05 pm ] |
luke3411 wrote: Hopefully they dont get stab the tank. Wouldn't be suprised. I really hope that it is a deterrent and they just move on to the next car. you would be better of with a sticker on the flap that says "diesel only" |
| Author: | sideways [ Wed May 01, 2013 12:12 pm ] |
LPG tags. |
| Author: | joel [ Wed May 01, 2013 5:58 pm ] |
just make it smell of employment and sense of purpose. that should keep them well away. |
| Author: | ball [ Thu May 02, 2013 11:15 am ] |
joel wrote: just make it smell of employment and sense of purpose. that should keep them well away. |
| Author: | Jezza86 [ Thu May 02, 2013 5:35 pm ] |
the locals here wont sniff premium 95 octane. ive heard it dosent give them the same buzz so they dont even try. dont know for sure. |
| Author: | whincup [ Thu May 02, 2013 8:39 pm ] |
atari4x4 wrote: ended up running the fuel pump to drain 50l out of the sucker. how long did that take roughly? i've always wondered how quick fuel pumps pump... |
| Author: | missmyljdaze [ Thu May 02, 2013 8:50 pm ] |
easy fixed- just run that opal fuel stephen |
| Author: | ball [ Thu May 02, 2013 10:29 pm ] |
missmyljdaze wrote: easy fixed- just run that opal fuel stephen wash your mouth out. That stuff is rubbish and should be eradicated from the face of the earth |
| Author: | Reubs [ Thu May 02, 2013 10:33 pm ] |
atari4x4 wrote: FYI vitara's have an anti siphon ball thingo in the neck of the tank... i tried draining the tank on the SWB by siphoning it & failed to get a hose any deeper than the filler neck. ended up running the fuel pump to drain 50l out of the sucker. I had no trouble sucking fuel out of a LWB 1.6 Vitara filler through a 1/2" poly irrigation hose. Not too hard to get past the trap with some poking around. Problem was I didn't have enough skill to siphon properly and got a few very nice mouthfuls of fuel! |
| Author: | ZukinLao [ Thu May 02, 2013 11:01 pm ] |
Jezza86 wrote: the locals here wont sniff premium 95 octane. ive heard it dosent give them the same buzz so they dont even try. dont know for sure. That's why they are stealing the fuel? Here they take it to actually use it in an engine... Guess either way your fuel is gone. They at least leave you enough to get home? |
| Author: | SuziBlu [ Fri May 03, 2013 10:36 am ] |
ball wrote: missmyljdaze wrote: easy fixed- just run that opal fuel stephen wash your mouth out. That stuff is rubbish and should be eradicated from the face of the earth Heard this before, but only in passing. Can you tell what/why its crap ? Interest only, 98 for me, nothing less. |
| Author: | ball [ Fri May 03, 2013 11:52 am ] |
SuziBlu wrote: ball wrote: missmyljdaze wrote: easy fixed- just run that opal fuel stephen wash your mouth out. That stuff is rubbish and should be eradicated from the face of the earth Heard this before, but only in passing. Can you tell what/why its crap ? Interest only, 98 for me, nothing less. It has a very poor shelf life (less than a month in your tank) Increases fuel consumption dramatically unless you listen to bullshit propaganda from federal government and BP that say it doesn't. Doesn't work in small 2 stroke engines. Really doesn't burn that well. It took 40 litres of opal to get the shitbox limo to burn when 5 or 10 litres should have been more than enough |
| Author: | atari4x4 [ Fri May 03, 2013 12:11 pm ] |
ball wrote: SuziBlu wrote: ball wrote: missmyljdaze wrote: easy fixed- just run that opal fuel stephen wash your mouth out. That stuff is rubbish and should be eradicated from the face of the earth Heard this before, but only in passing. Can you tell what/why its crap ? Interest only, 98 for me, nothing less. It has a very poor shelf life (less than a month in your tank) Increases fuel consumption dramatically unless you listen to bullshit propaganda from federal government and BP that say it doesn't. Doesn't work in small 2 stroke engines. Really doesn't burn that well. It took 40 litres of opal to get the shitbox limo to burn when 5 or 10 litres should have been more than enough far out, that's just ridiculous, no wonder it doesn't work in engines. |
| Author: | ball [ Fri May 03, 2013 12:40 pm ] |
the line of fuel poured out to a safe distance to light up burned that slowly I could walk faster than the flame front. It was more like diesel than fuel. It also has an oily residue when you get it on your hands. |
| Author: | shep [ Fri May 03, 2013 12:47 pm ] |
Can't use the shit to wash parts and my chainsaw won't even pop on it let alone run good enough to actually chop something up |
| Author: | alien [ Fri May 03, 2013 4:22 pm ] |
Divert the fuel filler hose to somewhere else that's quite hidden, and run the factory filler hole to a small "pee tank" - ie: roadside urination into the tank... then leave the flap popped open to make it more appealing for someone to wrap their lips around =) lol |
| Author: | luke3411 [ Fri May 03, 2013 6:01 pm ] |
alien wrote: Divert the fuel filler hose to somewhere else that's quite hidden, and run the factory filler hole to a small "pee tank" - ie: roadside urination into the tank... then leave the flap popped open to make it more appealing for someone to wrap their lips around =) lol Lol I like it!! Drove past some tourist's today siphoning a tank of a dumped car. Fk that would be funny if someone set that up |
