It is currently Sun Oct 18, 2026 4:36 pm
Vehicle: Coil Sierra
Post Posted: Tue Apr 30, 2013 7:32 pm
After removing my carby i noticed this small hole on the carby base plate, its the water jacket thingy for the choke. There is no hole in the inlet manifold. Got me thinking its eaten a hole through.
Post Posted: Tue Apr 30, 2013 8:03 pm
That's normal, it heats the carby for cold weather, or you get carb freeze at speed.
Post Posted: Tue Apr 30, 2013 8:12 pm
Thanks mate, I scraped off the gasket and cleaned the port out seems ok. The gasket has no hole that lines up with it. Do you know the water travels into a jacket in the inlet manifold or does it just stop against the paper gasket?
Post Posted: Tue Apr 30, 2013 8:19 pm
Mine stopped dead at gasket. Tho mine was an early model.
I bet the carbs are all the same anyway
Post Posted: Tue Apr 30, 2013 8:32 pm
Thanks again
Users browsing this forum: No registered users and 124 guests
