| Is this normal - carby base/water choke port http://auszookers.com/forum/viewtopic.php?f=5&t=40630 |
| Author: | coily96 [ Tue Apr 30, 2013 7:32 pm ] |
| Post subject: | Is this normal - carby base/water choke port |
After removing my carby i noticed this small hole on the carby base plate, its the water jacket thingy for the choke. There is no hole in the inlet manifold. Got me thinking its eaten a hole through. |
| Author: | christover1 [ Tue Apr 30, 2013 8:03 pm ] |
| Post subject: | Re: Is this normal - carby base/water choke port |
That's normal, it heats the carby for cold weather, or you get carb freeze at speed. |
| Author: | coily96 [ Tue Apr 30, 2013 8:12 pm ] |
Thanks mate, I scraped off the gasket and cleaned the port out seems ok. The gasket has no hole that lines up with it. Do you know the water travels into a jacket in the inlet manifold or does it just stop against the paper gasket? |
| Author: | christover1 [ Tue Apr 30, 2013 8:19 pm ] |
Mine stopped dead at gasket. Tho mine was an early model. I bet the carbs are all the same anyway |
| Author: | coily96 [ Tue Apr 30, 2013 8:32 pm ] |
Thanks again |
