| Adding 2inch spring lift http://auszookers.com/forum/viewtopic.php?f=5&t=40683 |
| Author: | red_elmo [ Fri May 03, 2013 5:37 pm ] |
| Post subject: | Adding 2inch spring lift |
Hi guys, just wondering if I'm going to have to extended my break lines on my Suzuki sierra. I already have a 2inch body lift and now adding in 2inch EFS springs. Do I need to extend the brake lines? Any help would be great. |
| Author: | PORL [ Fri May 03, 2013 5:48 pm ] |
| Post subject: | Re: Adding 2inch spring lift |
No you will be fine. I have the same set up minus a sway bar. Even on full flex no need for extended lines:) |
| Author: | PORL [ Fri May 03, 2013 5:49 pm ] |
Oh, sorry I got a Jimny though |
| Author: | Scrawny [ Fri May 03, 2013 6:25 pm ] |
Never needed them on my Sierra but others have. Best to just fit the springs, flex up the car and check to see if they're stretched |
| Author: | sideways [ Fri May 03, 2013 6:53 pm ] |
PORL wrote: No you will be fine. I have the same set up minus a sway bar. Even on full flex no need for extended lines:) It depends on your shock absorber length, you can stretch the Sierra lines with the 81340 shocks that most people use. Sierra lines are very short. I can't speak for Jimnys though. |
| Author: | PORL [ Fri May 03, 2013 8:06 pm ] |
IDE say jimnys are longer then. |
