http://auszookers.com/forum/
Diff swap
http://auszookers.com/forum/viewtopic.php?f=5&t=40692
Author:  Jebus [ Sat May 04, 2013 12:30 am ]
Post subject:  Diff swap
Hey first time post, long time reader ,
I've seen a lot of threads explain holiday diff swap etc
But I'm wanting to take a set of 1.3 diffs and put them on my 1L LWB
Is it a straight swap or do I have to re welding the diffs with new u bolt
Mounts on the diffs ? Is the chassis the same between the two ,
I'm still looking but if anyone knows a thread for this conversation will be very helpful
Thanks :peaceout:
Author:  Gwagensteve [ Sat May 04, 2013 9:41 am ]
Post subject:  Re: Diff swap
NT 1.3 axlehousings will straight swap, but the tubes are a larger diameter, so you ill need the u bolts and ubolt plates from a 1.3.
WT 1.3 axlehousings aren't a straight swap at all, the spring pads need to be removed from the axle and welded back in closer together.
Author:  Red89 [ Sat May 04, 2013 11:22 am ]
viewtopic.php?f=14&t=5293
Author:  joeblow [ Sat May 04, 2013 3:38 pm ]
Do you have a Maruti or Jap build Sierra?
Author:  BlueSuzy [ Sat May 04, 2013 5:47 pm ]
Its a serria. :wink:
