It is currently Wed Oct 14, 2026 8:11 am
Vehicle: Vitara G16b , Sierra G16b
Post Posted: Sat May 04, 2013 10:02 pm
Hi, just installed a full set of ome leaf springs to my sierra and now its got a very bad lean. (drivers side.)
I thought I got medium load 40mm but it didnt really raise it anywhere 40mm if not nothing!
I have done a full ruff so ordered 2x sets of rears. Now 3 of them have a '0' marking on them and 1 with a '|'. I put the ''|'' on the passenger front side because I thought it meant minus. (hope this was right?)
Was I meant to get 2 with '0' and 2 with '|'?
I have removed the bottom 2 load leafs on all of them too. (3 left in all packs)
The code on leafs are 1AC13.
Also, is the lean mainly cause by the front?
Post Posted: Sat May 04, 2013 10:39 pm
In my experience with RUF LWB, playing with the front springs has much more effect on lean than playing with the rears.
Post Posted: Sat May 04, 2013 10:40 pm
What was your before and after bottom of rim to guard measurement?
Post Posted: Sat May 04, 2013 11:24 pm
Not sure but what I do know is that my 35's are rubbing a lil now and didn't hardy do it before. I think this is because the shackle is squatting more that what it use to be because of the leafs being slightly longer.
Post Posted: Sun May 05, 2013 6:46 am
I thought OME springs were marked with a '+' on the drivers side spring pack.
Vehicle: 1985 lwb sierra UTE
Post Posted: Sun May 05, 2013 7:03 am
The way ome mark there springs is...0 is spot on to there spring free height any thing above is over they normally have a +,- on most of there springs.
With ome u should always stand the spring upside down and measure from the ground to the spring were the perch seats .this is called free height then u put the tallest on ur right hand side ,unless the mark a and b on them then a goes to the drivers side .
I would take back a pair and ask for some taller rears. Put the lower ones in the front and the new taller ones in the back ,
Vehicle: 03 Jimny
Post Posted: Sun May 05, 2013 8:11 am
this may be your problem, how did you do your ruf setup?
Users browsing this forum: Google [Bot] and 360 guests
