| Jimny wont start, weird clicking sound coming from engine http://auszookers.com/forum/viewtopic.php?f=5&t=40711 |
| Author: | sam_516 [ Sun May 05, 2013 1:04 pm ] |
| Post subject: | Jimny wont start, weird clicking sound coming from engine |
went to go to bunnings and when i pulled up and came back to the car it started, shuttered and stalled, turnt it over again, started shuttered and stalled agine. went to start again and it wouldnt, but had 1 good backfire. jumped out and checked fuel pressure, spark and fuses, plenty of fuel pressure, fuses are fine ( i sprayed with wd40 then blew out with air compresser anyway, same with the plugs and leads) but had no spark. didnt throw up any engine light when stalling, tho yesterday when i was driving to the beach it threw a engine light on for about 2 k's then went away so i disconected the batterys and put the brakes on and turnt the car to start to try and clear any falt codes to try and make it home (mechenic mate i rang told me to do this) but still no spark but there is a wird clicking sound coming from this thing behind the fuel rail, looks like a round thing conected to a plate and has a eletrical plug coming off of it which looks like it goes to the coil packs. just waiting on the old man to finish moving my sister then he is going to tow me home and ill take a photo of the thing making the clicking noise (sounds like a cricket.) also i have changed out the cam sensor only a few thousand k's ago, has brand new leads, plugs, coil packs, and i washed the engine bay out yesterday afternoon after going on the beach so might of shorted out something ( has had over 12 hours drying time befor starting it after washing) looked up on the service manual and it says to check/ clean/ replace the ckp sensor or ckp sensor plate or relace the ecm.... any idea where these are located/ look like? |
| Author: | alien [ Sun May 05, 2013 1:27 pm ] |
| Post subject: | Re: imny wont start, wird clicking sound coming from engine |
a few weeks ago there was a thread on water in the coil packs etc... take a look there. perhaps take all the coil packs / leads out so the spark plugs can get some air for a few hours (in the sun if its sunny over there). seems a bit coincidental this is happening the day after you washed the engine bay. |
| Author: | sam_516 [ Sun May 05, 2013 2:59 pm ] |
Yeah probably something simple, always is just tried starting it again, drove 2M then stalled and started making the ticking noise, so thinking something is just shorting out from being wet..... Love petrol engines.... |
| Author: | alien [ Sun May 05, 2013 3:23 pm ] |
you should try narrow it down to fix though - imagine being out wheeling, go through a puddle, engine bay gets wet and the same issue happens out in the middle of nowhere! |
| Author: | sam_516 [ Mon May 06, 2013 8:16 am ] |
It threw a engine light last night so should be able to get a scan tool onto it now |
| Author: | Scales [ Wed May 08, 2013 5:53 pm ] |
| Post subject: | Re: Jimny wont start, weird clicking sound coming from engin |
might be just a secondary fault code - IE. not the cause of the problem, just a second thing thats failed as a result.... obd readers wont work, you need to do the fault light thing with the paperclip, dunno how to do it on a g13 |
| Author: | sam_516 [ Wed May 08, 2013 5:58 pm ] |
Fair enough, there is a thread on here ill look it up |
