It is currently Wed Oct 14, 2026 11:58 am
Vehicle: 1989 jx tin top
Post Posted: Wed May 08, 2013 10:48 pm
Hi again guys
I was wondering.. If I do a leaf over axel conversion on a zook, standard springs, standard shocks,
what will need upgrading? Break lines? Shocks?
cheers Trav
Post Posted: Wed May 08, 2013 10:55 pm
Without going into the complicated answer that is required, I'm pretty sure that SPOA is no longer approvable in WA.
Post Posted: Wed May 08, 2013 11:04 pm
brake lines, driveshafts, shocks, trac bar, wider or more offset rims - the list goes on and on.
and fatzook is right - no one will engineer a SPOA sierra in WA.
For the cost of doing that conversion - IMO you're better off spending the $ on doing a very neat guard chop and re-spray - then do a RUF conversion and run a 32" tyre on a 16" rim (or thereabouts)... you won't get the tyre size engineered, but the rest is do-able without even doing a lane change test (providing you run stock rims and tyres and the RUF conversion only gives 2" of lift). It'll look ridiculous, but it will pass and an engineer should have no probs signing off on it.
Users browsing this forum: Google [Bot] and 275 guests
