It is currently Sat Oct 17, 2026 11:59 am
Vehicle: 1997 Suzuki Sierra
Post Posted: Sun May 12, 2013 7:39 pm
http://www.lowrangeoffroad.com/index.ph ... lifts.html
Will this kit fit the Coily sierra?
Post Posted: Mon May 13, 2013 7:59 am
Yes it will fit the coil sierra - I have used the same body lift parts for a coil and leaf sierra. However, why not buy a body lift from a local supplier? Just Cruzin and Fatzook both have ads for body lifts in the business section, which are made here.
Check the requirements for a BL in your state too - I'm not sure where you are, but Just Cruzin's kits are legal in QLD and perhaps most other states, but are definitely not legal in Victoria. Fatzooks are legal everywhere.
The lowrange kit won't be legal in Victoria.
Post Posted: Mon May 13, 2013 8:02 am
Why will some kits be legal and others be illegal?
Post Posted: Mon May 13, 2013 8:09 am
I'm in NSW by the way
Post Posted: Mon May 13, 2013 8:13 am
Just cruizin does a kit with alloy block now to keep the crazy southerners happy.
Post Posted: Mon May 13, 2013 8:23 am
It's not like we get a choice or anything...
Post Posted: Mon May 13, 2013 9:10 am
QLD allows the use of plastic/nylon lift blocks whereas Victoria insist you use aluminium or steel.
So a kit with nylon blocks will be perfectly legal in QLD and make you a criminal in Vic.
Don't know the rules for NSW.
Post Posted: Mon May 13, 2013 9:27 am
"Criminal" might be a bit strong a word, but it would attract a defect notice. As there is no fine or demerit points attached to this, it's more an inconvenience than anything, but best avoided.
Likewise, I don't know the rules for NSW.
PS the nylon/urethane lifts made by Just cruzin contain a steel sleeve, and I have no issue with their performance or safety myself, we just cant use them down here. As far as I am aware the low range kits do not contain a steel sleeve and I wouldn't recommend them, regardless of what state you are in. I am sure they are work, but I wouldn't run them.
Post Posted: Mon May 13, 2013 12:31 pm
My poly blocks for the fixed body studs don't have crush tubes as the female bolt acts as the crush tube. Same material as what's used for mobile crane baseplates, tested to 20 tonne.
Post Posted: Mon May 13, 2013 12:35 pm
And somehow, still not good enough for VICroads :roll:
I thought NCOP was about indtroducing common sence and uniformity accross the country :roll:
Post Posted: Mon May 13, 2013 1:17 pm
*sigh* - not again :roll:
I don't think what cranes use for base plates is relevant to what vicroads will accept. That's not a value judgement, it's just a comment. We're not going to change vicroads mind about this, and it's not likely to be resolved through the NCOP, considering we've been working within the limitations of the ncop here in Vic for many years.
Post Posted: Mon May 13, 2013 1:28 pm
I think the powers that be have just played it safe and excluded that group of materials all together, as there is no easy way to identify the material composition from the side of the road. Some grades would be less resistant to petrocarbons, lubricants and the like.
Post Posted: Mon May 13, 2013 4:42 pm
I have tried talking to the relevant engineers however to ones capable of undertaking and approving the calculations aren't interested in 4WDs and the ones who do the 4WDs aren't knowledgable enough or willing to qualify the design. At the end of the day the blocks are sitting on 12 to 40mm of rubber. The product I supply is an engineered product.
Vehicle: MG410 Gypsy
Post Posted: Tue May 14, 2013 2:49 pm
hookdawz buy justcruzin's kit.
easy to fit and install with support directly from him. great product, great service.
Users browsing this forum: No registered users and 167 guests
