| Grand Vitara Oil Filter http://auszookers.com/forum/viewtopic.php?f=5&t=40865 |
| Author: | Built4thrashing [ Mon May 13, 2013 8:03 pm ] |
| Post subject: | Grand Vitara Oil Filter |
What oil filter is everyone using. The Ryco No for the H25A V6 is Z172 and the J20 4cly is a Z418. Is it ok to use the Z418 filter on a V6? They have the same size thread, same diameter but the Z172 is about 20mm longer. I ask as its sometimes hard to get the Z172 off the shelf at some places and the difference in price is quite alot. |
| Author: | shabz [ Mon May 13, 2013 9:44 pm ] |
| Post subject: | Re: Grand Vitara Oil Filter |
I'd imagine that the Z172, being larger, would have a higher flow rate....could be wrong though |
| Author: | shandy92 [ Mon May 13, 2013 10:27 pm ] |
depending on how much long it is, you would get better filter life because of the surface area of the the filter is greater, blockages occur less. |
| Author: | Built4thrashing [ Tue May 14, 2013 5:06 pm ] |
The difference in length is less than 20mm. I plan to start doing oil changes every 5000kms. Doubt it will cause any problems with short changes. |
