| Lift kit questions http://auszookers.com/forum/viewtopic.php?f=5&t=40879 |
| Author: | MikeyS [ Tue May 14, 2013 8:52 am ] |
| Post subject: | Lift kit questions |
hi i was just wondering if i get a pro comp 3" lift kit do i need any of the following??: 1. Steering dampener ? 2. Castor Correction Bush Kit Offset 2.5 Deg ? 3.Castor corrected radius arms to suit 3" lift ( http://www.jimnybits.co.uk/shop/jimny/s ... d_442.html ) 4. extended brake line? |
| Author: | 4x4xzook [ Tue May 14, 2013 2:47 pm ] |
| Post subject: | Re: Lift kit questions |
hey mate, most people will chime in soon telling you to do a search. haha but good luck |
| Author: | tim80z [ Thu May 16, 2013 6:47 pm ] |
MikeyS wrote: hi i was just wondering if i get a pro comp 3" lift kit do i need any of the following??: 1. Steering dampener ? 2. Castor Correction Bush Kit Offset 2.5 Deg ? 3.Castor corrected radius arms to suit 3" lift ( http://www.jimnybits.co.uk/shop/jimny/s ... d_442.html ) 4. extended brake line? 1. No. 2 or 3 (but not both) Yes. Preferably 3. 4. Yes. - Tim. |
| Author: | Skippy [ Thu May 16, 2013 8:33 pm ] |
i have some radius arms with caster correction you can have. up to you whether you go that way or corrected radius arms. |
| Author: | macguyverjimny [ Fri May 17, 2013 1:36 am ] |
FYI, I think you might need a prop spacer aswell...12.5mm thick, i think |
| Author: | MikeyS [ Fri May 17, 2013 9:07 am ] |
thanks tim80z for info:) hey skippy yer that would be great. thanks macguyver jimny |
