It is currently Mon Oct 19, 2026 10:33 pm
Vehicle: 2013 Suzuki Jimny
Post Posted: Tue May 14, 2013 6:14 pm
been taking my jimny out on pretty boggy sand and it seems to have a burning clutch smell if it works to hard? first of all is that common?
It didnt bother me because the smell went away and the jimny still performed fine, took it out this morning and the same smell but worse and at times I couldnt put it in gear? plus when I eventually got it in gear the performance seemed off to its usual standard? have I blown my clutch?
Post Posted: Tue May 14, 2013 6:17 pm
Yet to see a blown clutch. You've burnt it and worn it prematurely. As to how much life it has left..... probably not much
Post Posted: Tue May 14, 2013 6:20 pm
Most likely burned out the clutch.
But mud, sand and water may have got into it.
Or clutch cable is starting to jam up.
Post Posted: Tue May 14, 2013 7:03 pm
Yea probably worth taking it in having somebody look at it
Post Posted: Tue May 14, 2013 7:07 pm
maybe your riding the clutch?
you in low range?
Post Posted: Tue May 14, 2013 7:17 pm
I was in high then hit a soft patch tried getting it out and started to smoke! popped it in low and it only made it smoke worse
possibly riding the clutch I tend to do it sometimes without noticing
Post Posted: Tue May 14, 2013 7:46 pm
And there's the answer.
Time for a new clutch, and some retraining to keep your foot off of it.
Post Posted: Tue May 14, 2013 8:02 pm
What tyre pressures were you running??
Post Posted: Tue May 14, 2013 8:54 pm
Does your clutch have any free play?
Users browsing this forum: No registered users and 212 guests
