It is currently Sun Aug 02, 2026 12:08 am
Vehicle: Suzuki Jimny
Post Posted: Mon May 20, 2013 10:03 pm
Im running a 2inch EFS lift on a 2011 Jimny. Would a rear panhard and or shock relocation brackets be needed or improve my setup?
I also get a clunky sound from the rear suspension when it articulates. Would either of these brackets get rid of this noise?
Any info or opinions would be much appreciated. Thanks.
Post Posted: Tue May 21, 2013 8:31 am
Afaik the clicky clunky noises are normal.
I don't believe panhards or relocation brackets should be required at 2" they won't make the noises go away at any rate.
Others may have a different experience though.
Steve
Post Posted: Tue May 21, 2013 8:41 am
As Steve said, although adding the shock relocation brackets will save your rear shocks from bending or popping the bush out of the shock eye, you may need a limiting strap or coil retainer though to stop your rear coils from falling out.
Vehicle: Suzuki Jimny 2009
Post Posted: Tue May 21, 2013 7:21 pm
The noises from the rear are probably the coil springs moving on the spring seat. Another possibility is the exhaust which hangs pretty loose on the rubber hangers and can move around a lot. My muffler used to hit the tow bar.
I don't think the relocation brackets are needed and if you use the shock relocation brackets you need to be careful about fully compressing the shocks.
One thing you should do is fit adjustable panhard rods. The after market ones are much stronger than the original ones. I agree with the others that for 2" lift you won't need any relocation brackets.
Post Posted: Tue May 21, 2013 8:48 pm
Ok thanks for the advice guys, ill give to relocation brackets a miss and look at some aftermerket panhards in the future.
Any idea on which are the set to go for? Tough dog? Jimny nits? ORA?
Post Posted: Tue May 21, 2013 9:42 pm
I rather prefer the type that can be adjusted on the car. Some need to have one end free to be adjusted but that type at least can never work loose. One thing to watch is the shape of the front Panhard. The Left Hand Drive models use a different shape rod and I am sure that some of the designs for sale here are actually for the LHD vehicles. I got mine from Outdoor Auto in Brisbane but I think they are all pretty much the same and all better than the stock rods.
Post Posted: Tue May 21, 2013 10:37 pm
pretty sure ODA just import from JB anyway.
They work fine on RHD models
MY BUILD THREAD HERE!!!!!
Post Posted: Wed May 22, 2013 6:52 am
ODA and JB order from the place. I had my panhards before JB existed.
Post Posted: Wed May 22, 2013 7:23 am
JB is now designing and building their own
Post Posted: Wed May 22, 2013 7:40 am
They've still got the blue panhards listed and the black ones in the 3" kit look the same except for being painted black. Even has the same bushes.
Post Posted: Wed May 22, 2013 8:24 pm
Yeh I think he might be still testing them. Donno, just remember seeing it the last time I jump into their website under "news" blog. Prob those black re the new ones, no idea. The way he was building them was the same concept of the blue ones tho
Users browsing this forum: No registered users and 1219 guests
